Regenerative braking
Not sure if anyone needs to be this example, but just in case it might be of use to someone not familiar with EVs I took three photos
1. One Pedal on, accelerating
2. One Pedal Off, still accelerating
View attachment 133473. One Pedal Off, foot of the accelerator coasting, no breaks but active regenView attachment 13348
With one pedal off region still does its thing, but it does not apply any level of braking. I doubt the majorityof people in this forum need this, but you never know. 🙂
I may try to have my wife photograph some of this on ours sometime.
For my Ioniq 9, regen level 0 provides 3kw or so of energy.
Level 1 is something like a max of 15-20kw.
And off the top of my head I want to say one pedal (level 4) provided as much as 75-90kw of braking.
(For context 750w = = 1horsepower, so 90kw of regen is the equivalent of 120HP of acceleration, backwards)
The highest level of regen I’ve seen in my car has been 107 but that was while going down an incredibly steep offramp using both the brake pedal and Regen on demand in one pedal drive, so it only stayed that high for a couple of seconds because the exit kind of snuck up on me. My highest regen in normal cases is in the mid 20s low 30s. If I take my foot fully off the pedal in one pedal drive if I slowly lift my foot off and allow the car to slow in one pedal it kind of tops out around 16-19
Stumbled into this thread and am now really interested by it.
How widespread is "car sickness" with drivers with this kind of braking?
I have a really difficult time with motion sickness unless I am the one driving (its super fun on planes and trains), but admittedly don't have any tangible EV experience to see how it would impact me.
I think it really is as I stated above it varies on driving style. I’ve never made someone that I know has motion sickness feel sick in my car because generally, I’m smooth in my release of the accelerator in one pedal and even if I take my foot fully off the car has a decent decline in speed. It doesn’t lurch or jerk. While on the other hand the first time I let my mother drive my car with one pedal on she made me feel a little motion sick. Had a rough start because she was unfamiliar with that kind of driving and it was very jerky for pretty much the entire drive. I told her she could take one pedal off and it would feel more normal to her, but she wanted to try it.
EV Car sickness feeling is really down to two separate things.
1) In an EV, it is quieter. And the normal audible cues we have to be able to tell if we're trying to accelerate or slow down (engine noise rising/disappearing) are typically gone. Imagine closing your eyes as a passenger, and going for a drive. With a gas car, you'll probably be able to tell if the driver is going to be accelerating, or not.
Believe it or not there is actually research on this. And EV brands are trying to find ways to add cues to the inside of the car (as an adjustable setting), to help combat this.
2) Heavy regen on throttle liftoff is a common feature of EV cars (called "one pedal driving"). This is where you lift off the throttle, and the car will start decelerating, and come to a full stop (and won't creep forward). Because this deceleration is strong, and the throttle response of an EV is quicker than the average gas car, if you have "herky jerky" throttle control, you can make your passenger feel carsick.
This herky jerky driving style is somewhat of a response to how a gas vehicle with an automatic transmission will "coast" (with light deceleration), allowing you to sort of "stab the throttle" and then lift off. So people have been somewhat trained in some cases to drive with less optimal throttle control. And people like that, are more likely to cause their passengers to get sick.
Personally, this is why I find the regen level adjustment to be nice. There are situations where heavy throttle based braking/regen is helpful (anytime you're dancing between brake pedal and throttle constantly, like at the airport dropoff in traffic that is constantly changing). But I also find that on relatively open road/highway, I prefer a much lighter regen level, so you can feather off the accelerator without impact easier. But of course its all personal preference.
Never had a complaint in the 7 years of EV ownership.
I hope Scout follows GM's path. NO PADDLES! Just blend regen on the brake pedal and also have a toggle for one pedal driving. Go drive a new Equinox or Blazer EV. They nailed it IMO (this coming from a 16-year Tesla owner). IMO paddles are a gimmick to live out someone's F1 fantasies. Yes, if you do not use OPD and are on a long downhill you will "ride" the brakes but this will just be regen and will not smoke your brakes. It would be helpful if there was some visual indication of when you hit max regen so you know if you're into friction brakes or not.
If we absolutely must have paddles, make them buttons on the rear of the steering or somehow out of my line of sight (or have a simple screw so I can remove them without taking the entire steering column apart). 😇
Tesla's method stems from the original Roadster. The cars were built by Lotus (they were modified Elise chassis). To save money and time they used Lotus' DOT approvals for things like the brakes so they could not modify them. When it came time for the Model S, they kept it the same - motors on the right pedal, friction brakes on the left. You clearly knew at all times which system you were using. To be fair, back in the early 2010s, brake regen on hybrids was TERRIBLE. As you would press on the brake it would regen, regen more, then BAM the friction brakes would grab. Modern cars have fixed this but the die had been cast with Tesla so they have left it this way.
Regarding car sickness and EVs, it is a combination of much higher torque (at zero rpm) than ICE vehicles and regen. In an EV you have 100% torque available at all times. Unlike an ICE if you move your foot a little the car will move a lot. The more powerful the EV the worse this is which would explain @cyure's experience (Rivian's are quite powerful). In my Model X Plaid the accelerator goes from 0 to 1,050 ftlbs in one stroke so the increase in ftlbs per inch is quite high! OPD definitely takes a little practice - you can't just jump off the accelerator like you can in an automatic. But very quickly you will learn to just modulate your foot to get exactly the power you need. It is really intuitive once you give it a try. My foot almost never moves off of the accelerator.
Reactions: Logan and J Alynn
NO PADDLES!!!!
Reactions: 6-ScoutFamily
This is very useful. Mine does something like this, although its more of a "shows you a bar that fills with regen". I assume that when you are braking, and the regen bar is all the way filled, that it blends into friction brakes. But AFAIK there isn't an actual "hey, you're riding your brakes" light.
I'm actually on team paddles myself. I change between the 5 regen settings I have somewhat frequently, depending on the situation. If that adjustment was hidden away in some menu somewhere, that would make that more difficult. Its not a deal breaker if they don't exist, but I do like them.
The situations are sort of specific, and generally I do leave it in one setting. But I'd say I change it a few times on any given drive. One of the situations is driving from my house, to the nearby town. Its nearly all downhill (500ft elevation difference). With regen set to level 0, we can basically freewheel most of the difference, without riding the brakes, or applying throttle. Heck, I even manually downshift on my automatic vehicles on grades, so adjusting the regen to help with the grade you're dealing with, feels pretty normal to me.
In congested traffic with lots of lane changes (where adaptive cruise control doesn't work well, like airport pickup/dropoff lines), I actually like 1 pedal.
Do I have to adjust it so much? No, I'm sure I don't. But, TBH, even if all it does is make it more engaging to drive/like I'm doing something (sorry, used to drive a manual :D), I'm ok with that.
Out of curiosity-have your other cars had paddle shifters? I only ask as I’ve had them on my Acuras and on our Honda pilot and I use them all the time. I think people who have used paddles really like them and those that don’t have or don’t use probably don’t have the same outlook. Just curious on that. Not a right or wrong but just curiosity
Older GM EVs had a single paddle ROD (Regen On Demand) it was even in the the first editions of the Silverado EV personally from my GM experience. I do prefer having a button to change one pedal from off to on and then a paddle for when I need it to be stronger
I have never had PADDLES in a car so I have no idea if I would like PADDLES or not. 😹
I love the PADDLES on Kia/hyundais. They’re pretty much invisible from driver position, so no danger of offending anyone, and they make a very easy way to adjust regen for different driving conditions or preferences. Bring on the PADDLES! 🤣
Read about EV sickness - never experienced it, but I have extreamly limited EV experience too. Some might be driving style - some is most likely a change in clues that we have become accustom to. I used to get car sickness - and still do if I can not watch the road. Second row is bad, third row I feel like hell. Reading in a car - well more migraine headaches than sickness, but yep, rarely ever try that either.
I think the sickness I get happens when I don't get visual clues of what is happening (I am much better riding in the passenger seat if I am still paying attention to the road). With EV's, you tend to get less/different audio clues as well. Inner ear sends signals of motion, you are not telling your body to move, many of the rest of the clues of motion are missing - so your mind is wondering what is going on and you feel "off".
I said much better - still not 100%. I really don't like being a passenger. My wife is no better. Being able to feel the car through the steering wheel might be it - or maybe it is simply a trust issue. I have no sea sickness in a kayak while paddling - small boats that I have to hang on to and can see well, no problem. make the boat larger (so I don't have to hold on) and take away my sight lines, dramamine please (for a day or two). It does not help a lot (still feel bad), just less nausea bad.
Amazing how losing a horizontal line can instantly make you sick
Reactions: cyure and maynard
Just to clarify, I’m good with regen and even one pedal. I just want to ability to turn it off totally so I can coast (unlike some cars where you can’t).
My Volvo has it on or off. I can turn it off when my wife is in the car. It’s not totally my driving, it’s been this way for 19 years it’s not going to change.
Just trying prevent some marital strife. Don’t want to get her car sick before we even get to the off road trails 🎊🤓😉
I have never had paddles. My ICE cars have been manual shift (1985 Nissan pickup, 2000 TJ, 2003 WRX, 2006 Corvette) or regular automatics (2007 WK Diesel). That being said, I understand their use in an ICE that has a transmission to shift gears. But... EVs don't have gears. This is bewildering to me. I do get @Logan's comment that it gives them something to do (increases engagement) as long as we are all clear that it is a gimmick designed to mimic an ICE car and doesn't have an actual purpose in an EV.
The beauty of an EV is it's simplicity. You have all available power and all available regen on the accelerator- if you want to go faster, push the right pedal more, if you want to go slower, push the right pedal less.
Reactions: LastDayScout
