Harvester towing
mbeadnell
Jun 24, 2024
40
51
Upvote 11
Just adding another data point for the wonderful scout employees who check these threads for feedback.
The only thing keeping me from pulling the trigger on a reservation is the unconfirmed towing capacity of the harvester models.
I need to be able to tow a 3600 lbs car quite often. Uhaul trailer is 2210 lbs. Sum it up and you get just under 6000 lbs. 7000 lbs towing would be the perfect sweet spot, I really hope the Terra can hit that mark!
Thanks for offering your first post. If towing is critical for your use I fully understand the hesitation. Time will tell.
Welcome to the community!
Reactions: Crazychicken563
I hope @Jamie@ScoutMotors can provide clarification when he has information in hand. I wish the CEO had not released until final specs were published. I can only assume (personal opinion here don’t go chopping me down here) but as a truck person towing is a big component of not one of the biggest. If you limit that you are going to lose a lot of people. Everything else about the truck is wonderful it would just be a shame for that to be the reason.
FYI- something to keep in mind. A vast majority of the Harvester reservations I am sure were made BEFORE he mentioned the 5k towing. I am sure some have dropped off and others will if that number does not change. The other small percentage may not care but a vast majority do.
Same, that one comment caused a lot of turmoil and I don’t even tow!
It really seems like us tow-wanters are classified as a niche group, but surely we are not that small.
I own an EV already, so I have absolutely no reason to migrate platforms unless I can gain access to long distance drives and pull my track car along the way.
EREVs are the perfect compromise of components that enables absolutely everything I would want from both an in-city daily driver AND a long distance hauler. The only two options coming out in the market for that use case are the Scout Terra and the Ramcharger 1500. And lord knows the last thing I want to do is give money to Stellantis. I've tried out their interior and their U-Connect infotainment was awful to use. Plus the Ramcharger is absolutely overkill with their claimed towing capacity. I'm far more interested in overlanding than having a monster work truck.
Regarding reservations, I'm still waiting for official performance numbers. Until those happen I won't be pulling anything. I'm sure many of the other harvester reservations are in the same camp. They keep marketing the harvester as something that "alleviates range anxiety", but having owned an EV for years now with only 200 miles of range, I can absolutely state that range anxiety is NOT the driving factor for the desire to have the harvester onboard.
I agree with this…..however 7500 towing range is a sweet spot. I greatly believe this with alleviate the issue for many. That would make a drastic improvement for many.
Yeah anything >= 7k would be absolutely perfect!
I did comment earlier in this very thread that "The only thing keeping me from pulling the trigger on a reservation is the unconfirmed towing capacity of the harvester models."
I thought about it a while and decided to speak with my wallet and put a reservation down anyway. I have faith that the company is in tune with the needs of the community, and so my reservation only gets pulled depending on what the final specs will be.
Glad you joined us with your reservation. And yeah faith and patience. That’s all we can do right now.
I can see buyers considering the BEV Terra if enough positive response comes about and people can reduce concerns over range anxiety. I know some just can’t with location but I think many may come around if willing to learn and trust real user experience. But you absolutely make a fair point about towing capacity.
After a weekend in the woods jumping between my TRX and my brother’s Colorado, I’ve come to the conclusion that my next truck doesn’t need to be as wide as a school bus. I’ve got a Traveler Harvester reserved, but I’m thinking of switching to a Terra Harvester. However, if the tow numbers are 5,000lbs then the Terra does me no good. I need a truck that can safely tow our family pontoon boat, and I just am not comfortable with the 5,000lb number. Get me to 8,000lbs and we’re golden. A truck has to be able to do truck things, and a 5,000lb tow limit falls short of being able to do truck things.
Is the Terra not as wide as your TRX. Is that what you mean?
