Bigger Gas Tank - 15 Gallons is Abysmal
Demlockian
Jul 1, 2025
8
16
New Mexico
First, let's review battery basics, as I understand them: for optimal daily use, electric vehicles (EVs) are generally recommended to stay within an 80% maximum State of Charge (SOC) and avoid consistently dropping below a 20% minimum SOC.
To maximize the longevity of an electric vehicle's battery, a practical guideline is to consider approximately 60% of the battery capacity as the usable range for daily driving. This stems from adhering to an 80% SOC upper limit for and avoiding consistently dropping below a 20% SOC, which minimizes battery stress and degradation.
Realistic Driving Use Case
With an effective 60% SOC window the Harvester's 150-mile range translates to roughly 90 miles of usable range. This effectively addresses the daily driving needs of average commuters, as urban commuters typically travel 20-30 miles round trip (leaving approximately 65 miles of extra range) and rural commuters travel 40-60 miles (leaving around 40 miles of extra range).
For longer journeys, the Harvester's ability to add 300 miles (stopping at 1/6 tank remaining) of range (23.3 MPG) is invaluable. Considering that the average long-distance family road trip is roughly 750 miles (per ChatGPT), and the Scout with the Harvester can travel approximately 390 miles before refueling, a single 15-gallon refill extends the range to 690 miles, enabling completion of the average road trip with just two stops.
However, range is significantly impacted when towing a trailer. According to ChatGPT, towing at 70% of a vehicle's maximum capacity can reduce range by approximately 40%. This would decrease the EV range to around 55 miles and the gasoline range to 175 miles (accounting the same 1/6 remainder stop), resulting in a total of 230 miles per cycle. Therefore, completing a 750-mile trip would require refueling the Harvester approximately four or five times, considering that only 175 miles of range are added with each gasoline refuel.
In contrast, a Ford F-150 with a 3.5L EcoBoost engine achieves an estimated 22 MPG on the highway and has a 36-gallon fuel tank, translating to a towing range of nearly 395 miles per refueling stop (stopping at the same 1/6 tank remainder). This enables the F-150 to complete the same 750-mile trip with half (or fewer) the refueling stops compared to a Scout Terra equipped with the Harvester while towing.
All of this is to say that the 15-gallon proposed gas tank size is severely inadequate for real world towing applications. To be comparable, the Harvester needs an optional 25-gallon or larger tank. The 25-gallon tank option would raise the initial range to nearly 600 miles useable, which competes with similar trucks in the segment. Furthermore, it increases the standard towing refuel range from 175 (abysmal) to nearly 300 miles (acceptable). Bigger would still be preferred personally.
Generator Use
It's hard to speculate how long the Harvester would last in generator mode without further details, but let's do some shade tree math here. A 10kW gasoline generator uses about 2.5 gallons of fuel per hour at full load. According to ChatGPT, the average single occurrence power outage is roughly 2.5 hours, allowing the 15 gallon tank to be adequate (only used 6.25 gallons). However, in coastal areas power outages can be upwards of 72 hours due to large storms. With an upgraded 25-gallon tank, the homeowner (or renter) would have 10 hours of uninterrupted service, enough to sleep through the night comfortably (the 15-gallon tank only provides 6 hours).
Reactions: CRobin
Well, I wondered when I would recognize someone's else's screen name from the AZ VJC in here. Welcome @Demlockian. No way there's two Demlockians out there.
Small world! I left Arizona for the military about 12 years ago now... Finally stationed somewhere close by again (New Mexico). Noticed the AZ VJC forum is pretty much dead now. Once I finish up the D60/14B swap on the JT I'll have to look into the Facebook version to catch up on some rides. Really missing Montana Mountain and Box Canyon in Florence Junction area.
Which goes back to one reason I wanted the Scout Terra... I have to move every ~3 years and the military authorizes anywhere from $1.00 to $2.00 per pound of household goods that I move myself and my allowed limit is around 14,000 pounds ($14k-$28k). For wheeling, the Scout could pull my Jeep (~9K lbs on trailer) or the majority of household goods with the Jeep pulling the remainder.
Yeah the forum and website are dead. The admin who owned the domain moved from AZ to NC several years ago and then stopped maintaining the site, so eventually it crashed. A few of the other members who are savvy IT people tried getting it running again, but for whatever reason it never came to fruition. The landing page still has this message: "Hey, gang. It has been a long year with everything going on, but we are finally there. Mingoglia should have the forum operational by the end of the week. Thanks for sticking through it.".
We've been looking forward to the end of that week for about 5 years lol.
Generator Use
I agree! I really hope they use a bigger gas tank starting out. 15 gallons is just ridiculously low for the size of vehicles they are producing alone. That doesn't even address the road trips and or towing a trailer as you mentioned. Scout NEEDS to have a larger gas tank period.
So I’ve asked this question before with similar thoughts. What do you give up under the vehicle to gain that space? Maybe there’s a great solution SM hasn’t thought of yet that somebody else has, but there is only so much room. So just curious what should be given up to make that work. Trying to think how you fit 6-7 more 1-gallon jugs under the vehicle without giving something up. Is it a secondary tank under the Terra and you force the spare to the truck bed? Give up 20-25% of the battery pack?
Just curious on people’s thoughts-thanks
Agree, if they're fitting a 15 gal tank into space that is occupied by battery in the non-Harvester version, then the only way to fit more tank into the space would be at the expense of battery, so they would have to put an aux tank somewhere else in the vehicle.
When I was lugging a 5 gal jerry can around on my YJ's rear tire carrier, I also carried a $20 self priming Super Siphon in my onboard toolbox. This enabled me to jam one end of the siphon into the gas tank and the other end into the Jerry can, give it a couple of shakes to start the transfer of fuel, then step back and let it flow. A minute or two later I was good to go. Cheap and easy way to expand the fuel capacity by, in this case, 33.33333333333333333333333333333333333333333%.
Old-school is new-school. I love it.
Generator Use
Very well played. This would be a deal breaker for me! My Altima has an 18-gallon tank. There's no reason why a larger tank couldn't be done. I know it's early, and will have to wait and see, but i could be sticking with my original plan of getting a Land Cruiser.
Welcome to the community.
Okay I have a question for those of you wanting a larger gas tank. They have said with the Harvester you get 150 battery + 350 from the range extender for a total of 500 miles. That’s with whatever gas tank size it’s going to have.
So those of you asking for a bigger gas tank are you wanting the range to be more than 500 miles? Because if the range stays the same but they put in the bigger gas tank you are asking for that would just mean it’s less efficient.
Just curious what you all are thinking.
Welcome again.
Welcome again.
I'm not the sharpest knife in the drawer, but larger tank will get you more miles. It's still early. By the tank size the mpg would be a little over 23, not bad. It would just mean your range on gas only would extend beyond 350 miles. Good question, and I'm a new member, so what do i know, ha-ha
Someone on here can. Correct me if I’m wrong, but we don’t actually know how big the tank is at this point. At least I didn’t think we did.
I want to retract my previous statement about being a deal breaker, it would definitely be better with a bigger tank. I'm just excited that there's a good chance of me owning a Scout. I've always wanted one, and now that could be reality. I have been mostly Toyota all my life, and it's time for a change!
dont remember hearing the size of the gas tankard all those numbers about capacities and not going below a certain level of battery charge makes me even more nervous about the whole electric thing,i was going to buy the new Yukon Denali but waiting on a engine replacement for the 6.2 with all the troubles GM is having, so there are things you have to consider when buying any of these vehicles....I imagine the Scout and the new Gm 6.6l will be coming out at the same times I already have a 1978 Scout SSII,not sure which way I will go.....leaning towards the scout....
Here's what I remember:
I believe Scott said they were thinking about a 15-gallon tank back in a MT podcast. But... Jamie said something about them the gas tank being under the rear seats for better weight distribution, in a thread about towing. Which would be different from what the harvester platform looks like on the website. So, the tank could be bigger than the 15 Gallons. 15gal was said back when the tank was said to be up front like a Porsche, but I guess the engineers found that the tow capacity was hurt by having too much rear weight, so they swapped the battery and fuel tank position for better weight distribution.
Welcome again.
I might be wrong, but when I see most people talking about the tank size it often sounds like they assume once the battery is depleted it swaps to an engine to run the electric motors, instead of a regulated RPM VW Generator to start replenishing SoC.
Why do new members always start by complaining? 15 gallons is in the same realm of 85% of all ICE vehicles. Why should the Scouts have more. I don’t understand why so many people think the Scout should offer more than the ICE’s they will compete against. The Broncos gets 20mpg on a good day and have a 16.(something) gallon tank for a range of 320 miles. I ask again-why should the scout have more. If SM adds every extreme everyone asks for this thing will be $150K. This is an EV/hybrid brick on wheels. Let’s all be reasonable because if these vehicles climb past $80K nicely equipped SM will probably lose 40% or more of their buyers. SM has to have done their research and knows where price points need to be. They would not have started a $2 billion dollar endeavor if they hadn’t. Want more range buy the integrated Jerry cans and then you will have the extra range. But to say 15 gallons is abysmal is really funny. Especially since that 15 gallons (which hasn’t been officially confirmed-that I know of) is on top of an additional 150 miles of battery range. Rant over!
I thought the comment was click-bait. 15gal is more than enough.
I’ve mellowed out here the past three years but I think there is a lot of clickbait here and I’ve learned to be calm and take an educated approach and have civil debate. I like it here way more now that I don’t just get bent out of shape
