Harvester towing
mbeadnell
Jun 24, 2024
60
78
Upvote 13
Wait, now that is a pedestrian warning we can all get around. If someone would dare step out in front of this rig, or somehow not hear the thunder of the exhaust stacks…they are met with this.
That would be the premium audio system! I was thinking like 8-10 speakers for the base system. But seeing the flames made me think-will it come with or have optional Nitrous in case a Tesla pulls up next to me and wants to drag race?
Reactions: LastDayScout
Instant campfire, use only permitted subject to local laws and ordinances.
Image result for smokey the bear certificate
@BartMan Terra Total EV what do you think of this little guy?
Specifications​
Measurements​
Trailer Size (Lift Up): 16.5ft (200” x 86” x 114”)
Trailer Size (Lift Down): 16.5ft (200” x 86” x 83”)
Box Size (Lift Up): 133” x 86” x 114”
Box Size (Lift Down): 133” x 86” x 83”
Toolbox Size: 22” x 22.5” x 26”
WEIGHT
Tare Weight: 3660 LBs.
Curb Weight: 4100 LBs.
Water Tank: 1x 42 gal (160L) clear PE water tank, 1x 18 gal (70L) black PE water tank, 1x 18 gal (70L) grey PE water tank, with 12V electrical pump
Layout​
Bed: 51" x 78.7"
Mattress Size: 51" x 78.8" x 3.94"
Appliances​
Electrical: 2 × 100 A/H Deep Cycle Batteries, Overload protection, Cigarette sockets, Water sensor, Voltage meter (DC & AC), 1000w inverter, Solar power control
Kitchen System (Indoor): ARANA American standard gas stove, tempered glass cover
Kitchen System (Outdoor): Integral outdoor kitchen
FEATURES & CHASSIS​
Suspension: Independent suspension with dual air shock absorbers, coil springs
Brakes: 12” electric brake plus additional hand brake included, brake away system
Draw-Bar: Pointed 360-degree universal hitch
Safety Chain: Dual (not single) drawbar safety chains
Chassis: Heavy duty off-road galvanized chassis
Rims and Tires: 265 75/R16 LT tire, 16" aluminum alloy wheel, including spare
Finish: All aluminum sandwich panels lightweight frame
Reactions: Latrant
This might have already been suggested but I wanted to ask about the generator placement. Since the anticipated towing capacity on the Terra Harvester has dropped from 10,000 to 5,000 I have seen some suggestions that this is due to the Harvester Generator being placed on the rear axle and that is what limits the towing capacity. Why not put the Harvester Generator under the hood and eliminate the frunk? If given the choice between having a 10,000 lb towing capacity with the Harvester Generator and no frunk vs 5,000 lb towing capacity with the frunk available (generator mounted on the rear axle) I would definitely rather have the 10,000 lb towing capacity and no front trunk. Maybe this has already been discussed and maybe having a front trunk is more desirable to the majority? But for me personally, I would rather have the generator under the hood in a traditional placement with 10,000 lb towing capacity rather than 5,000 with a frunk.
Welcome to the forum!
This was two pages back. At this time this is about an official response as we can get from Scout about towing capacities.
Just going off of what many people here have said, most would prefer retaining the frunk. Jamie also confirmed there are test mules running around so packaging and drivelines are most likely finalized for the first generation Scouts.
Thanks!
No worries!
For what its worth many of us share your concerns and dont want you to feel alienated or anything. There are just a lot of unkowns and we are trusting that Scout is aware of it and trying to do their best to give us as much capability as they can.
Right now my motto is “faith and patience”. SM hasn’t let me down yet so I’m choosing to have faith and this is a situation where I have no choice but to have patience.
What I will say having seen them in person, is whenever the concepts are close to you I would highly recommend going to see them. It’s worth it. Even not being able to sit in them, it’s still worth it to go.
Knowing the engineers are checking here, just chiming in to also say a higher towing capacity is critical to lure some of us away from 1500 and 2500 tow rigs. I'd MUCH rather have a SUV to tow my dump trailer and move equipment occasionally; right now a Ram 1500 with just under 12k towing capacity does the job; the new Ramcharger (electric and range extender) is rumored to have a 14k tow capicity, which is tempting, BUT a Scout SUV with 10k or more would do what I need most of the time. Lots of folks pulling boats, enclosed trailers and such in that range (up to 10k). 5k tow capacity won't cut it. Even my wife's Cayenne has a 7.7k tow capacity... I suspect safety regulations have far more to do with what the final capacity will be than actual capability. Here's hoping the engineers win out!
Reactions: Latrant
Welcome to the community!
Welcome.
Many here would agree with your feelings about it.
I am not sure how far back you’ve gone in these threads but the BEVs still have 7,500lbs for the Traveler and 10,000 for the Terra.
We will just have to wait and see.
I am sure they know there are billions in potential sales if they can get this right for the American market.
One thing that makes me hopeful is they are being built and designed by Americans like us, not half way across the world where public transit exists everywhere and you’re rarely stuck in a car for more than a few hours.
I’m hoping the design team and engineers give us something that is safe, reliable, comfortable for cross country trips, and packed with capabilities.
Reactions: Latrant and J Alynn
Have Cancelled My Terra Reservation
Placed reservation in first week after the big show & tell.
As more specifications or likely specifications are discussed I've decided for now Terra won't meet my needs.
Biggest factors:
- Harvester tow rating
- discussions on how all electric drives have traction issue or reduced power due to angles on steeper inclines
- Overall size of vehicle is too big
  • Sad
Biggest factors:
Sorry to hear that. Ultimately I hope everyone finds the vehicle that meets their needs and makes them happy.
SM has not provided detailed specs yet on a number of things. I’m just back to my motto, faith and patience. In time we will have definitive answers.
Good luck to you in your search!
Biggest factors:
Guess it ultimately wasn’t meant to be.
There are some articles out there about these kinds of questions. You’ll see a lot of different results.
For the winter, if you do the things you should do for emergency situations (bring a blanket, jacket, etc), you can survive being stopped and needing the heater to stay warm for something like 100-150 hours with the battery in the Lightning. If you don’t have those things, I would expect to be able to survive with some range left to get to a charger for about 50-75 hours. I would worry about other things before I would worry about the battery. If you have an electric blanket or two in the vehicle and it has outlets, you can use even less energy, but check that the blanket works with your vehicle’s inverter before you get in the situation—some electric blankets use a kind of component that isn’t friendly to the kinds of inverters used in vehicles.
For the summer in a place like Needles, CA—which often reaches the highest temperatures of any large city in the world—the AC requirements can be more demanding than the heater requirements in the winter—bundling up is socially acceptable, but dressing down isn’t so much. I used around 1.5% of the battery while stopped for that hour. The real problem was that I drank all of my ice-cold drink and really needed a bio break.
But just being stopped in traffic on a mild spring day? Basically no loss. You don’t even have to worry about turning the vehicle off. It just isn’t using any energy to sit there doing nothing. That’s one of the best things about EVs: Idling isn’t at all a thing to worry about. Even if you have the vehicle in a garage, you can warm it up (or cool it off) without worrying about carbon monoxide.
You never cease to amaze me with your experiences and analysis. Can I ask what “age group” you are? If you are a Boomer like me or close to it, how much paradigm shifting have you had to do?
