Bigger Gas Tank - 15 Gallons is Abysmal
Demlockian
Jul 1, 2025
8
21
New Mexico
First, let's review battery basics, as I understand them: for optimal daily use, electric vehicles (EVs) are generally recommended to stay within an 80% maximum State of Charge (SOC) and avoid consistently dropping below a 20% minimum SOC.
To maximize the longevity of an electric vehicle's battery, a practical guideline is to consider approximately 60% of the battery capacity as the usable range for daily driving. This stems from adhering to an 80% SOC upper limit for and avoiding consistently dropping below a 20% SOC, which minimizes battery stress and degradation.
Realistic Driving Use Case
With an effective 60% SOC window the Harvester's 150-mile range translates to roughly 90 miles of usable range. This effectively addresses the daily driving needs of average commuters, as urban commuters typically travel 20-30 miles round trip (leaving approximately 65 miles of extra range) and rural commuters travel 40-60 miles (leaving around 40 miles of extra range).
For longer journeys, the Harvester's ability to add 300 miles (stopping at 1/6 tank remaining) of range (23.3 MPG) is invaluable. Considering that the average long-distance family road trip is roughly 750 miles (per ChatGPT), and the Scout with the Harvester can travel approximately 390 miles before refueling, a single 15-gallon refill extends the range to 690 miles, enabling completion of the average road trip with just two stops.
However, range is significantly impacted when towing a trailer. According to ChatGPT, towing at 70% of a vehicle's maximum capacity can reduce range by approximately 40%. This would decrease the EV range to around 55 miles and the gasoline range to 175 miles (accounting the same 1/6 remainder stop), resulting in a total of 230 miles per cycle. Therefore, completing a 750-mile trip would require refueling the Harvester approximately four or five times, considering that only 175 miles of range are added with each gasoline refuel.
In contrast, a Ford F-150 with a 3.5L EcoBoost engine achieves an estimated 22 MPG on the highway and has a 36-gallon fuel tank, translating to a towing range of nearly 395 miles per refueling stop (stopping at the same 1/6 tank remainder). This enables the F-150 to complete the same 750-mile trip with half (or fewer) the refueling stops compared to a Scout Terra equipped with the Harvester while towing.
All of this is to say that the 15-gallon proposed gas tank size is severely inadequate for real world towing applications. To be comparable, the Harvester needs an optional 25-gallon or larger tank. The 25-gallon tank option would raise the initial range to nearly 600 miles useable, which competes with similar trucks in the segment. Furthermore, it increases the standard towing refuel range from 175 (abysmal) to nearly 300 miles (acceptable). Bigger would still be preferred personally.
Generator Use
It's hard to speculate how long the Harvester would last in generator mode without further details, but let's do some shade tree math here. A 10kW gasoline generator uses about 2.5 gallons of fuel per hour at full load. According to ChatGPT, the average single occurrence power outage is roughly 2.5 hours, allowing the 15 gallon tank to be adequate (only used 6.25 gallons). However, in coastal areas power outages can be upwards of 72 hours due to large storms. With an upgraded 25-gallon tank, the homeowner (or renter) would have 10 hours of uninterrupted service, enough to sleep through the night comfortably (the 15-gallon tank only provides 6 hours).
Reactions: RJ29er and CRobin
Welcome to the community.
Okay I have a question for those of you wanting a larger gas tank. They have said with the Harvester you get 150 battery + 350 from the range extender for a total of 500 miles. That’s with whatever gas tank size it’s going to have.
So those of you asking for a bigger gas tank are you wanting the range to be more than 500 miles? Because if the range stays the same but they put in the bigger gas tank you are asking for that would just mean it’s less efficient.
Just curious what you all are thinking.
Welcome again.
To me the magic is 500 miles on a single tank/charge. If that comes with a 15 gallon tank I’m good with it. I had a Ford Raptor that would go 500 miles on a tank and it was fantastic (my TRX will never claim that kind of range). 150 miles on the battery alone means it fits my day to day commute, and then for long road trips the 500 mile range kicks in. The only concern I have (and @Jamie@ScoutMotors answered this a while back), is the gas and go situation where a trip is say 500 miles. Jamie said the Harvester will be a gas and go vehicle, so if your trip is say 600 miles, there shouldn’t be any concern.
Here's what I remember:
I believe Scott said they were thinking about a 15-gallon tank back in a MT podcast. But... Jamie said something about them the gas tank being under the rear seats for better weight distribution, in a thread about towing. Which would be different from what the harvester platform looks like on the website. So, the tank could be bigger than the 15 Gallons. 15gal was said back when the tank was said to be up front like a Porsche, but I guess the engineers found that the tow capacity was hurt by having too much rear weight, so they swapped the battery and fuel tank position for better weight distribution.
I’m not stressed about it.
The aftermarket industry always fills in the gaps.
My motorcycle has a 3.4 gallon tank that is integrated into the rear subframe, and the factory airbox is where a normal fuel tank would be under the seat.
I wanted more range and a company in the Czech Republic makes a 1.6 gallon Auxillary tank that replaces the factory airbox with a smaller one that filters better.
So now I have 5 gallons of capacity and can ride over 230 miles on a fill up.
My Lexus GX470 also has multiple options for larger fuel tanks, that can give me over 50 gallons of capacity if I need it.
If you don’t want Jerry cans hanging off the back when you need the extra range, I am sure there will be a company that offers an oversized fuel tank, or a smaller auxiliary one.
A deal breaker for me is something that can’t be fixed by the aftermarket, like a low payload or towing rating.
Otherwise it’s just part of the off-road focused vehicle experience. They are like Legos. You can add and remove all kinds of things to suit your needs.
I'm not the sharpest knife in the drawer, but larger tank will get you more miles. It's still early. By the tank size the mpg would be a little over 23, not bad. It would just mean your range on gas only would extend beyond 350 miles. Good question, and I'm a new member, so what do i know, ha-ha
23mpg is attrocious for an EV. Why carry around the battery at all. Just go for a gas truck with cylinder deactivation and mpg will be higher
I don't believe 500 miles would be gas and go for another 500 since the battery and gas would both be depleted. The question is going to be whether the vehicle will drive with a completely depleted battery. That would only allow driving another 350 (maybe less?) miles after filling up.
Generator Use
I’ll speculate a bit on this.
The battery in the Harvester model is good for around 150 miles, EV trucks tend to get around 3 miles perk kWh, so as a rough guess the Harvester’s battery is about 50kWh. Overnight my house uses about 500W to power the water pumps on my heating system, and some network stuff and some lights and the freezers and fridge. So “overnight” for a generous 10 hour “overnight” my winter power use is 5kW, leaving me with another 45kW before the generator has to kick in. During the day with a power outage I tend to be more conservative then normal with power use of my power use only clips around 100W, during to more lighting, and using some high draw items like a coffee maker for a brief period of time, maybe a few minutes of 1500W microwaving later in the day. Still “only” around 600W for the other 14 hours, so 9 more kWh used during the day, for a total of 14kW per day. so for there and a half days I’m going to use the battery power not the generator. Or if we start from “only” 80% full we have 2.8 days. Which is a good start. Then the harvester kicks in using its tank of gas to make electricity for the other 350 miles of rang, so likely another 116kWh. It’ll stop when the battery gets “too full”, and I assume it’ll probably kick in when the battery gets “too low” as well, so maybe we get 2.5 days of quiet power and then the engine kicks in and runs for a few hours or whatever it takes to fill the battery (I’ll assume it cuts off around 80%?). Still that is all details, it’ll make a bit more power then is needed to fill the battery twice over whatever period of time is needed.
Which gives a total running time of about 8.4 days. If you are smart around day 7 while you still have a fair bit of range left you will forage into town for gas (hopefully the gas station has a generator). Or maybe you have a few gas cans in an out building? If you have to drive out of the blackout one you might want to figure out how big an area that is early on so you know how much range to reserve, although to be honest last time I had a “long” blackout it was only 3 days, and I cut shave driven 4 miles to a ga station outside of the blackout zine, or 10 miles to a DC fast charger outside of the blackout zone.
So I’m fine on the size of the gas tank in the harvester model. I do want a 240V outlet on the SUV though (concept mode's have one on the pickup, not the SUV, hopefully that is just a “we didn't think of it when we made the SUV” or “it is an option so we wanted to show it on some and not all to see who will pay an extra $200"
Makes me feel bad about my 70kWh daily usage in my house... :ROFLMAO:
Standard subject to change disclaimer as usual:
Final gas tank size will be announced soon. Final range figures once EPA testing is done closer to production.
Generally speaking, the generator will kick on when it thinks it is necessary. There will be a way to manually activate the engine/generator and also a way to use only the battery for as long as possible (ECO mode). There will also be a full Auto mode, where the computers determine needs. Electric motors are really easy to measure a tiny, tiny amount of resistance or load. So the vehicle computers will know immediately when there is additional load or weight in the vehicle (or towing something). So it takes that into consideration. It can also use your location via GPS (and any trip you enter into the GPS) to determine whether you are on a long trip with sustained high speeds. It obviously knows how fast you are driving as well. So if it sees that you are planning a long trip (just one example), get on a highway, and drive 80mph, the generator will likely kick on to help keep up with power consumption. Depending on the power consumption, the engine may not wait until the battery is depleted first (unless you force ECO mode but only down to a certain level) to start trying to stay ahead of the battery drain. In normal driving, you will run out of fuel before you run out of battery, and you can pull into a gas station, fill up, and keep going. Yes, if you were to create an extreme case where the car was fully loaded to max capacity, towing at max capacity, and going up a 6% grade at 80mph for two hours straight (unlikely scenario, I know), then you could drain the battery faster than the generator could keep up. Your choices are to slow down to reduce the load on the battery or pull over and let the generator recharge the battery enough to continue. Likewise, you could camp remotely and turn the generator on to charge batteries. You can also run the generator off-roading as well.
We will publish a LOT more information as we get closer to production launch. Meanwhile, our teams continue to keep making improvements.
Subject to change:
Generally speaking, the generator will kick on when it thinks it is necessary. There will be a way to manually activate the engine/generator and also a way to use only the battery for as long as possible (ECO mode). There will also be a full Auto mode, where the computers determine needs. Electric motors are really easy to measure a tiny, tiny amount of resistance or load. So the vehicle computers will know immediately when there is additional load or weight in the vehicle (or being towed). So it takes that into consideration. It can also use your location via GPS (and any trip you enter into the GPS) to determine whether you are on a highway. It obviously knows how fast you are driving as well. So if it sees that you intend a trip, get on a highway, and drive 80mph, the generator will likely kick on to help keep up with loads. All of this is not likely to happen right away as the vehicle will try and use the battery first. However, the engine may not wait until the battery is depleted first (unless you force ECO mode but only down to a certain level) to start trying to stay ahead of the battery drain. In normal driving, you will run out of fuel before you run out of battery, and you can pull into a gas station, fill up, and keep going. Yes, if you were to create an extreme case where the car was fully loaded to max capacity, towing at max capacity, and going up a 6% grade at 80mph for two hours straight (unlikely scenario, I know), then you could drain the battery faster than the generator could keep up. Your choices are to slow down to reduce the load on the battery or pull over and let the generator recharge the battery enough to continue. Likewise, you could camp remotely and turn the generator on to charge batteries. You can also run the generator off-roading as well.
Thats the most i think we have seen and heard about Harvester. Seem Harvester Powertrain development is moving along nicely
Very cool, I thought BMW i3 era EPA regs said an EV had to drain the HV battery before it could start the onboard generator if it wanted to be classed as an EV. I’m assuming since Scout “may not wait” that either those regulations have been relaxed, or the harvester is willing to be “not an EPA EV”, or “yeah, but you need to put the Scout in a non-key up mode to get this behaviour”, or something else is going on (like “no, you were wrong, BMW didn’t need to do it that way they just wanted to...maybe to make some other country happy”).
At any rate I’m glad to know the Scout has at least the option of being smart about when to kick in the generator.
Generator Use
This vehicle is EV The generator is supposed to be used as a backup not the primary means of power. This is going to be a vehicle you have to charge. Which I like and perfectly fine with.
Reactions: LonnyMacD
Generator Use
This is an EV vehicle the generator supposed to be used as a back up not as the primary power source. This is going be a vehicle you have to charge and honestly, I think 15 gallons and 500+ miles range is more than sufficient.
