The gas tank needs to be bigger on the Harvester models
JoeSchmoe
Feb 25, 2025
2
7
USA
I'm really excited that Scout is finally making a proper EREV truck and suv for the American market. I think Ford and GM should have launched their EV trucks with an EREV option from the beginning. The primary use case of my current Honda Ridgeline is to tow a small 14ft ,~2000 pound camper. It gets around 25 mpg normally on the highway and about 10-12 towing the trailer. High speed plus the aero drag of a trailer causes terrible fuel economy. We have high speed limits out west up to 80mph so I usually have to go at least 70 to not be run off the road. It has a 20 gallon gas tank which means I can only realistically go about 170 miles between fill ups while towing without getting super nervous especially if the gas stations are 30+ miles apart in the middle of nowhere.
If the EREV Scouts are going to get around 150 miles of EV range then 350 miles on the 15 gallon tank, that equates to 23mpg which should end up with the same 10-12 mpg when towing at highway speeds. The 15 gallon tank is really going to be a problem for longer drives. Sure I'd get about 75 miles towing in EV mode from the battery, but after that, if I'm just relying on gas for the rest of the trip, I only have a towing range of ~150-180 miles. You don't want to run until empty and with gas stations 30+ miles apart that makes your realistic towing range between stops close to 120 miles. This range limitation is already annoying in my gas truck with a 20 gallon tank. It's going to be much worse with only a 15 gallon tank. Having the gas can option is nice, but for regular trips, I don't want to have to pull over and use the gas can on the side of the road. That should only be for emergencies or extended off grid camping trips.
Please make the gas tank 25 gallons or bigger for those of us that tow.
Welcome to the community
Usually at highway speeds aero matters way more than weight unless you are climbing a hill. On flat ground you might see better mpg towing a 10k pound flatbed trailer with gravel than a 2k pound small RV like mine. It's like pulling a giant sail behind you.
I saw that the new Ramcharger EREV that is coming later this year reserves about 20% of it's battery no matter what to make sure it has enough power in hybrid/gas mode. It also will have a tow mode where it reserves 50% of the battery to make sure you can get up steep grades while towing.
I live in the mountains so the range lost by climbing grades matter a lot to me. They could simply run the towing test with a box trailer which has no aerodynamics with extra weight added to make it to max weight then one test solves both questions.
The ramcharger seems to have found a good solution to the increased battery usage from more load on the motors.
You sure it wasn’t the 35gallon gas thank with the V8 that was mentioned?😂
Don’t be silly-the V8 goes in the frunk. Granted there will be a LARGE hood bump so it fits but its design looks cool. They are going old school Mitsubishi eclipse with the hood bulge on just the passenger side (in matte black obviously). In that case they are making a 46 gallon tank (in red) that roof mounts like an aero storage case and the gas gravity feeds into the tank. There will then be an optional, option to add a water bladder (think giant camel pack) that fits inside the case just in case you need 46 gallons of water rather than fuel. Say you want to smuggle exotic South American fish back to your specialty pet store.
Everyone is covered that way!
I also hear they are developing rear window saddle packs (ie-defender inspired) that will mount hydrogen filler pods for that option. That will also (quite ingeniously) drain the water “exhaust” to a mini pump that pushes it up to the roof bladder. It’s the circle of life BABY!
Concept image
The interview videos of the reveal last month indicated that they will have (at least) three EREV driving modes for the Harvester. One of those modes is "max" which is designed for towing, so the Harvester will have a EREV mode like the Ramcharger.
I can personally attest to any Stellantis product(I had a JLURe for about 3 years) that the ~20% of that reserve gets eaten up real fast once they issue a recall not to charge it or park it inside, during winter of course, with no fix for 4 months.
Happened twice.
It'll now take me a lot to trust Stellantis with a hybrid/EV vehicle again.
Personally I disagree with the "need" part. I'm not at all saying you are wrong, I just have a different opinion. Great if the extra volume comes from unused space, but not if it means a smaller battery. We will spend about 80% of our Traveler's miles towing, 10,000+ miles per year.
We currently tow a 16' Airstream Basecamp with a 2023 Honda Pilot Trailsport. We generally pull about 3400 lbs, we do CAT Scale weighs whenever we change things much. We travel a lot on the west coast, Idaho, NW Wyoming (Yellowstone, Tetons), Nevada, and Arizona. We have not yet spent time in Colorado or Utah. We try to not go over 62, sometimes 65 if we feel traffic pressure. In a broad range of trips we average 15.5 to 16.5 mpg overall on towing days. I wonder how much of the difference is good Basecamp aerodynamics and how much is speed. Since drag increases with the square of speed, 72 mph has 35% more drag than 62.
Welcome to the community.
The EREV is going to get 350mi of EV range and the Harvester will charge the batteries for an additional 150mi. Not the other way around.
Easy to do since I don’t think it explicitly said on any of the main pages of the website, maybe buried in an FAQ or said in an interview, but the main takeaways from the site is 350 BEV and 500 EREV so it’s an understandable confusion
Reverse that. It’s 150 in pure BEV then an additional 350 from the gas generator. We all keep mixing it up
Sorry, but this is what’s posted in the specs. Am I confused right now, yes
So which is it?
Q: What manufacturer estimated range will Scout vehicles offer?
A: Scout Motors estimates the Traveler™ SUV and Terra™ pickup will have up to 350 miles (563 km) of all-electric range or more than 500 miles (804 km) for gas-powered range extender-equipped versions. These are manufacturer's projected estimate based on internal targets. EPA estimates will be provided when available.
So which is it?
EV Battery Chemistry NMC, Size 120-130 kWh 350 Miles Battery Range
EREV Battery Chemistry LFP, 60-70 kWh 150 Miles Battery + 350 Miles Range Extender
So which is it?
They’ve said mainly in interviews that the put batter range on harvester models will be 150, due to smaller batteries to accommodate the harvester systems. This is confusion is on scouts end, they don’t make it very clear on the website, but I assume that’s planned to change once the production models are finalized or with the first major website overhaul
So which is it?
The “or” is the key word in that answer. Separate the statement before and the statement after the word “or”. They are two different setups completely. Not the same battery in both. I can understand the confusion for sure though.
