Road Trip: Harvester vs EV vs Gas Hog
04Ram2500Hemi
550
1,768
Western Montana
So some of this is using Google Gemini, so take it for what it’s worth. The wife and I just did a 560 mile trip in one day, and it made me wonder how the gas hungry TRX would stack up against a Terra Harvester and a Terra EV. The trip took us 9 hours with two stops. So what follows is some Google help combined with real world data.
In the TRX we used 38.576 gallons at an average cost of $5.638 a gallon, we averaged 14.439 miles per gallon, and spent $217.50 on gas.
The Google Parts:
The Missoula, MT to Anacortes, WA route via I-90 W and I-5 N covers approximately 545–550 miles.
Comparing the travel time and operational cost between the Scout Terra EV (all-electric) and the Scout Terra Harvester(range-extended hybrid with a gas generator):
Key Powertrain & Efficiency Specs​
FeatureScout Terra EVScout Terra Harvester (EREV)
Powertrain SetupDual-motor All-ElectricAll-Electric drive + 4-cyl Gas Generator
Battery Size~120–140 kWh (estimated)Smaller battery (~150 mi pure EV range)
Gas TankN/A~15 gallons
Total Target RangeUp to 350 miles500+ miles total (150 mi EV + ~350 mi gas)
DC Fast ChargingUp to 350 kW (800V, NACS native)Up to 350 kW (800V, NACS native)
1. Travel Time Comparison​
Scout Terra Harvester​
  • Driving Time: ~8.5–9 hours
  • Stops: 1 quick stop
  • Total Time: ~8 hours 50 minutes – 9 hours 15 minutes
Breakdown:
  • Starting in Missoula with a full charge and a full tank gives you 500+ miles of range.
  • You can cover almost the entire 545-mile journey on your initial fill/charge.
  • You will only need one 10-to-15 minute stop (e.g., around Ellensburg or Cle Elum, WA) to splash 5–8 gallons of gas into the tank to guarantee reaching Anacortes comfortably.
Scout Terra EV​
  • Charging Time: ~35–50 minutes total (2 fast-charging sessions)
  • Total Time: ~9 hours 20 minutes – 9 hours 50 minutes
Breakdown:
  • At highway speeds (70–75 mph across Snoqualmie Pass and eastern Washington), real-world range drops below the 350-mile EPA target (roughly ~270–290 miles usable at 80%–10% SoC intervals).
  • Stop 1: Coeur d'Alene, ID or Ritzville, WA (15–20 mins on a Tesla Supercharger / 350kW DC Fast Charger).
  • Stop 2: Ellensburg or Cle Elum, WA (15–25 mins to gain enough top-off for the mountain pass and I-5 traffic).
2. Fuel & Charging Cost Comparison​
(Assumptions: Starting with home-charged electricity at ~$0.12/kWh in MT; Public DC Fast Charging at ~$0.42–$0.48/kWh; Regular Unleaded Gas at ~$4.20/gal average across WA/MT).
Scout Terra Harvester Cost:​
  • Home Start Charge (150-mi EV range): ~$5.00 – $7.00
  • Gasoline Consumption: (~400 miles driven on gas at ~26–28 mpg = ~15 gallons) ≈ $60.00 – $65.00
  • Estimated Total Trip Cost: ~$65.00 – $72.00
Scout Terra EV Cost:​
  • Home Start Charge (Full Battery): ~$15.00 – $18.00
  • Public Fast Charging (Mid-route stops): ~100–120 kWh added at public chargers ≈ $45.00 – $55.00
  • Estimated Total Trip Cost: ~$60.00 – $73.00
Summary Direct Comparison​
MetricScout Terra HarvesterScout Terra EV
Total Travel Time~9 hours~9.5 hours
Required Fuel/Charge Stops1 quick gas splash (10 min)2 fast-charging stops (40 min total)
Trip Energy Cost~$65 – $72~$60 – $73
Key AdvantageFaster travel time; zero range anxiety crossing Snoqualmie PassLower routine maintenance; zero tailgate emissions
My diesel F250 takes about $150 to fill these days (28 gallons at $5 - so maybe a bit more as $5 was a few weeks ago). I can get close to 450 miles on a tank (not towing). So the TRX is a thirsty beast - but so is my F250 at about $200 for that trip. Was supposed to go on an 1800 mile trip this week - seems cancelled. That was going to be expensive ($600 gas, plus 3 nights in hotels and 4 days eating out) - probably $1500-$2000 as half would be towing and then the mileage drops like a rock. Hard to guess how much, because it will be an extreamly light tow, with a fairly low wind drag cargo - a canoe on a jet ski trailer.
The Google Parts:
Breakdown:
Scout Terra EV​
Breakdown:
Is there a pricing flaw here? The Terra EV is penalized for a full charge of the battery and all necessary recharging. The Terra harvester is charged for the initial batttery fill up and the 15 gallons of gas we assume the tank holds, but a stop is required to refuel so more gas is being added, say 5 gallons? that's another $25+ and good luck finding gas for $4.20. That's $1.40 less than your stated cost. I also doubt the harverster will take regular fuel which could impact the calculus. The trip delta if I'm reading this correctly is only 30-45 minutes and not a full hour. That said, charge stops tend to take longer than advertised because people tend to be more relaxed and not in a rush so they often charge more than is required. Interesting numbers though. Sorry if I am misinterpreting then info.
Reactions: N Wilson
The Google Parts:
Breakdown:
Scout Terra EV​
Breakdown:
I noticed you used a $0.12/kWh for home charging as your base line. For those who don't have EVs yet but will be getting the Scout (this applies equally to the Harvester and the BEV), or for those who have EVs but don't do this, install contact your local utility company and get on their EV charging plan!!!!! We have Xcel Energy here, but I understand most--if not all--utility companies have EV charging plans. You're going to get the best rate per kWh with that plan.
To give you an example, I only get charged $.04/kWh (rounded up) for my truck charging. Now there are some stipulations that come with that. One, you can only charge between midnight and 6:00 a.m., at that rate (you set the schedule on your charger, not your car. Setting it on your car means you can't charge during the day elsewhere like DCFC). Six hours is plenty, even with my huge Rivian battery. If you take it too low, jsut start it before you go to bed to still get most of the good rate. Two, for Xcel, you have to use a ChargePoint HomeFlex charger. Frankly, it's a great charger. Works perfectly. Only costs about $500-600. They use that one because it connects to WiFi so they can read your charger to charge you appropriately. Three, you need WiFi to connect the charger to. I guess you can also get a separate meter at your house, but that's thousands of dollars so the charger/WiFi is far more cost effective.
My only direct experience with EVs are Tesla and Volvo but both of them have location-based charge scheduling. So the car knows when you're home and when you're not so you just set the charge schedule in the car and let it handle everything. I have been using the 14-50 plug-in "mobile" charger for all of my EVs for the past 16 years. Fancy chargers are not needed at all (unless in your case the utility requires it).
In my area, I just signed up for the Time of Use (TOU) rate. It makes power more expensive from 2-7pm M-F and radically cheaper the rest of the time. That rate was actually cheaper than my utility's EV rate. Bottom line is this varies greatly between utilities and also on your own usage patterns. We will be happy to help anyone decipher electric utility tariffs when the time comes.
A rough summary tells me the EV only version would be an hour ish longer than the Harvester version, but the cost between the two Scouts is the same. It also confirms what I already knew, that the TRX is a hungry fat bastard!
This was a good exercise. Out of curiosity-if you paid an average of over $5/gallon why did AI only use $4.20/gallon on the Harvester? Are you running premium on the TRX or just used what AI generated for the assumptions
To get a fun comparison albeit still nowhere near accurate, you really have to tweak the prompts. See below for a fun run through AI modeling. You constantly have to be on top of it or it gives bad data for even mundane things...
Total prompts and reruns made it too long to post and I had to hold its hand through a lot of things... (Gemini), so here is the cliff notes version below.
Here is the condensed, high-level summary of the 549-mile trip (Missoula to Anacortes) optimized for quick copying:
Three-Way 1-Stop Trip Comparison​
Vehicle Total Travel Time Total Cost En-Route Stops Required
Scout Terra EV (All-Electric) 8h 54m (8h 29m drive + 25m charging) $69.78 2 Stops (1 lunch stop + 1 quick charge splash)
Scout Terra Harvester (EREV) 8h 49m (8h 29m drive + 20m fueling/lunch) $77.66 1 Stop (Simultaneous 20m fuel & lunch)
2018 Ford Expedition (23.3G Tank) 8h 49m (8h 29m drive + 20m fueling/lunch) $109.80 1 Stop (Simultaneous 20m fuel & lunch)
Key Takeaways​
  • Time Winner: The Scout Harvester and Ford Expedition tie, beating the pure EV by 5 minutes. Because liquid fueling is so fast, both vehicles completely finish refueling within the 20-minute window, requiring zero additional stops.
  • Cost Winner: The Scout Terra EV is the cheapest, saving you $40.02 over the Expedition and $7.88 over the Harvester.
  • The EV Charging Bottleneck: The Scout EV requires 142 kWh of public energy to finish the trip with a 10% battery buffer. Because it can only absorb ~70 kWh during a tight 20-minute lunch break, it is forced to make a second, quick 5-minute stop later on.
  • The Fueling Constraint: For the gas and hybrid options, the fueling (5 mins) and eating (15 mins) must happen sequentially rather than simultaneously because US regulations prohibit leaving a gas pump unattended.
In the end it starts to report that the times are closer than we predict in a vacuum. @SpaceEVDriver has already proven this out with his many write ups.
I have no idea. Again - I let Google do the Scout work. I probably should have been more specific with Google. I’m not sure what fuel Scout will require.
From Google:
Compare travel time and cost from Missoula, MT to Anacortes, Wa in a Scout Terra Harvester vs Scout Terra EV vs Ram TRX. Average cost of gas is $5.638 per gallon. The TRX will average 14.4mpg
To compare these three trucks for a trip from Missoula, MT to Anacortes, WA, we'll use the standard route along I-90 W and I-5 N:
  • Total Distance: ~535 miles
  • Base Driving Time (No Stops): ~8 hours 30 minutes
Baseline Assumptions & Data​
  1. Gasoline Price: $5.638 per gallon
  2. Electricity Cost: ~ $0.15/kWh (home starting charge) and ~ $0.48/kWh (DC fast charging on I-90/I-5 corridor)
  3. Ram TRX: 14.4 MPG average (uses gas for all 535 miles)
  4. Scout Terra EV: 130 kWh battery (~350 miles EPA estimated total range; target consumption ~2.7 mi/kWh on highway)
  5. Scout Terra Harvester (EREV): ~65 kWh battery (~150 miles pure EV range) + 4-cylinder gas generator yielding ~350 miles on gas (targeting ~25–28 MPG equivalent once running on gas)
1. Cost & Travel Time Breakdown​
MetricRam TRXScout Terra EVScout Terra Harvester (EREV)
Fuel / Energy Used37.15 Gallons~200 kWh65 kWh (EV) + ~13.8 Gal (Gas)
Fuel / Charging Cost$209.45$79.80$87.61
Charging / Refueling Stops1 Stop (5 min)2–3 Stops (~70–80 min total)0–1 Stop (~5 min)
Total Travel Time~8 hours 35 mins~9 hours 50 mins~8 hours 35 mins
2. Vehicle Breakdown Details​
Ram TRX​
  • Fuel Consumption: 14.4 MPG535 miles=37.15 gallons
  • Total Fuel Cost: 37.15 gal×$5.638/gal=$209.45
  • Time Impact: Minimal stop time. One quick 5-minute splash-and-dash fuel stop is sufficient, adding negligible overall time.
Scout Terra EV (Pure Electric)​
  • Energy Consumption: Starting with a 100% full battery (130 kWh) in Missoula. Highway driving (~70–75 mph) will consume roughly 2.2–2.5 mi/kWh, requiring around ~200 kWh total.
    • Full home charge before departure: 130 kWh×$0.15/kWh=$19.50
    • DC Fast Charging along I-90 (~70 kWh total needed): 70 kWh×$0.48/kWh=$33.60
    • Total Cost: $79.80
  • Time Impact: Requires 2 to 3 fast-charging stops (e.g., Coeur d'Alene, Ellensburg) averaging 25–30 minutes each. This adds roughly 1 hour 15 minutes to 1 hour 20 minutes of dwell time.
Scout Terra Harvester (EREV)​
  • Energy / Fuel Consumption: Starts with a 100% charge (65 kWh) for the first ~150 miles. The remaining ~385 miles are powered by the gas-engine generator. Assuming ~28 MPG efficiency from the generator: 28 MPG385 miles≈13.75 gallons.
    • Full home charge before departure: 65 kWh×$0.15/kWh=$9.75
    • Gasoline: 13.75 gal×$5.638/gal=$77.86
    • Total Cost: $87.61
  • Time Impact: With a combined ~500-mile system range, you can complete the trip with either zero fuel stops or a quick 5-minute stop near the end, keeping total travel time matched to the TRX.
wow - that is super detailed! As I digest this, I found an article in the WSJ that helped slay my “EV Anxiety” fears, so long as the software on my new Scout will have similar smart features to plan routes and estimates for charging, as well as ability to use different charging stations….of course, the Harvester backup should eliminate any remaining fears. Bottom line: the Scout will be my first EV, and I feel pretty good about it with respect to charging fears:). https://www.wsj.com/business/autos/...8d420?st=y5Z1zR&reflink=article_copyURL_share
If you live in New England, your fears would have been worse 5 years ago. Now its pretty much a non-issue unless your going fishing in the Allagash or skiing on Khatadin.
I convinced my mom in her late 60s to get an EV. I convinced my sister in her 40s to get an EV. I convinced my friend in his 30s to get an EV. My neighbor just got his first EV. Every single one of them, without fail, have said they are never going back to gas and it’s the best car they’ve ever owned. I have high hopes you’ll love your Scout!
Once you go EV it just doesn’t make sense to go back
I keep hearing things like this. Very confidence inspiring.
Pretty good article - they guy in the Hyundai could have saved himself some worry if the rental person had given him a basic overview of the car's navigation system. Our Ioniq5 not only routes you to chargers, it will automatically find the chargers where we have an account if it figures out we don't have the range to complete our trip. Kind of freaked me out the first time it did it, we were driving late at night in a part of the state we don't know well, and the car was guiding us in what I thought was a strange direction: straight to a charger where we had an account! When I finally caught up with what the car was doing, we had a relaxing 10 minutes listening to the radio, and then on our way with no drama. I have to assume Scout's navigation will be at least that smart.
Now that we own an EV I’m amazed at how ‘smart’ they really are. I get occasionally they try to stop you sooner than needed but at least in doing so it prevents you from being in a bad spot. You can still choose to ignore it but that’s of your own doing
I haven't really started looking; but, are there any smartphone apps for PHEVs/BEVs/EREVs that can gather stats and calculate real-time total cost of ownership numbers?
I use a smartphone app called "Road Trip" for decades with data stored online in Dropbox so we can input and have access in real-time from any of our smart devices (iPhones and iPad). I haven't seen something similar to Road Trip for PHEVs, BEVs, or EREVs electrical data to be added/substituted along with the all other calculations (going for the EREV SUV for the reason for BEV+I.C.E. app)? Wasn't an issue with my two mild hybrids since 100% of the electricity used is generated by the V-6 I.C.E. or regen braking.
My current Road Trip app stores:
- current vehicle stats (mileage, fuel type, tire size, units, carbon foot print, etc..
- gas stops (location/date/time, odo reading, price, gas type, payment type, category like work/vacation/personal),
- calculates mpgs avg and other stats (miles driven, cost per for those miles, etc...),
- any/all expenses you want to track (wipers, tires, 12v battery, schedule/unscheduled maintenance, accessories, etc...),
- provide reminders on any mileage based maintenance items like tire rotations or cabin filters
- calculates road trip stats (vehicle stats and $$ spent on two week vacation to Yellowstone NP for example), and
- up to date total cost of ownership per day and per mile
My 18 RLX hybrid purchased used with 7200 miles in Dec/2019 cost me $2.22 per day or $0.12 per mile with +54,000 miles to date. Those numbers include fuel, accessories (window tint, PPF, floor mats, etc..), schedule/unscheduled maintenance, tires/alignments, replaced a pot hole bent rim, replacement of 12v battery, etc...
You might be able to change the setting for "desired arrival SOC" if you poke around.
I can do that on my truck, and its a great feature b/c I am not conservative at all and have no problem going into the single digits for % of juice left in the battery. LOL
