We own EVs. Ask Us Anything.
IMO, Yes. But.
I haven't found a great AS in the size I want and load range required. For the Lightning, 116S is the lowest load index I would put on the truck. There aren't a lot of great options outside of ATs. And as you go to a higher load index, the tires get a lot heavier. I would like an LT Touring kind of tire, but they can be 25% heavier, which adds a lot of rotational inertia.
Good points. And my range anxiety may be kicking in as well.
It probably is. :)
In my research, I've found that tread type isn't as important as sidewall construction. So, while I would like an AS, they're generally not as rigid in the sidewall as we need. So you end up trading out a minor impact on range (tread) for a greater impact (sidewall flexure) and end up with a more wobbly tire on turns and etc. And you lose cargo and towing capacity.
I'd like an AS built for EV trucks, but they're hard to find.
IMO, Yes. But.
Two years to go. Maybe new tire development t will be announced prior to with more EV trucks online maybe something is in development ?
