Traveler vs. Terra - Targeted Technical Questions
Terra will have a larger battery pack because there is more room between the wheel base thus adding more weight
Where are you getting that from? I have not seen anything that indicates the Traveler and Terra would have different battery sizes.
Just because the Terra has more space between the wheels doesn't mean they will put a larger battery in. IMHO, it would be better for Scout to keep the battery sizes the same, so they can use the same battery management hardware and software in both vehicles.
The Terra also seems to have a space allocated under the bed for a spare, so that could be the things that takes up the extra space, the wheel base and body add
I’m pretty sure Jamie said it somewhere along the line. Maybe I inferred more from it than what was meant. He just said more room for battery flexibility to I took that at face value. Maybe he meant room to push and pull battery location along with other components for better weight distribution, etc…
New here, been lurking. To the extent they can be answered now, interesting questions.
The one question I think I know the answer to based on my EV experiences (I also live at altitude) is that you shouldn’t expect any change at altitude on power output (not talking grade, just elevation).
Yes, electric vehicles (EVs) can be affected by altitude, primarily due to reduced battery efficiency in cold temperatures at higher elevations. Not on elevation alone.
