Special/First Edition Scouts
Just throwing my $.02 in on this.
I think classic style wheels, exclusive graphics, and a front locker would satiate me for a "Community Edition Package" or "Homecoming Edition Package".
I am still willing to pay more for other features because I want Scout to be successful, but would also feel like I have something special too.
It’s the like the Toyota 4Runner. That thing has 9 trims because for example they did the TRD Off-road which is the regular engine and then the TRD Off-road Premium which is the iForce max hybrid engine. That 4Runner is just too many trims.
What drove me nuts on that car is for example the TRD Off-road sport has a hood scoop but body color fenders. The TRD Off-road has a flat hood but black fenders. The only way you can get a hood scoop and black fenders is to move up to the TRD PRO and that jumps up in price and is limited production so hard to find.
I’m hoping the DTC model takes a lot of that frustration out and that we can order them the way we want them.
That’s why I think there needs to be a legit off-road package and then an off-road appearance package like Audi does with the ‘S’ line. Or just make all wheel available without full blown set-up like Bronco did. If you wanted the 35’s and beadlocks you had to go Squatch and it was what-nearly $8K. When I built my daughters with her she just wanted the larger wheels and a 2” lift which should have been like $3500 give or take.
Reactions: N Wilson and OH1984
Are the Bronco Wheels just lookers, or are they true beadlocks? I was under the impression that OEM's could not deliver trucks with beadlocks due to DOT regulations. Although I use my truck in places where AT tires are great, I don't do any type of rock crawling at all, have no plans to in the future and so I have no need for beadlocks, so I'm not sure whether that is accurate or not.
Reactions: cyure and OH1984
I’m pretty sure the Squatch packages were legit beadlocks. Maybe someone who has a Bronco on here can confirm
They were beadlock capable.
So the black diamond had skid plates and semi off road. The Sasquatch package cost more depending on trim level, and the upgraded hoss 3.0 which came on the wild track also had 35” tires but fox racing shocks, this is what I had.
Tbh I don’t plan to rock crawl my daily driver because I need to get to work and not risking destroying a $60k car. Large tires looked awesome, but maybe could settle for 33”. Those aren’t small either
I am still willing to pay more for other features because I want Scout to be successful, but would also feel like I have something special too. View attachment 6484
Very nice ride.
Nice. Miss our Bronco. Wish we wouldn’t have gotten a lemon
Reactions: OH1984
They were beadlock capable and shipped from the factory with beauty rings. You can order a bead lock kit that just bolts right up from Ford Performance. Those wheels now appear to be optional with the Sasquatch package with some trims, but not with others, with a default non-headlock capable wheel on some Sasquatch packages.
Ford did the “too many trim” things with the Bronco imo. At launch, you had 6 trims including the stripped down base trim (which actually saw a fair bit of demand) and the Sasquatch package (front and rear lockers, 35s, lower gear ratio, 2” lift with fancier shocks) was 2-5k depending on trim.
I saw someone here propose 3 trims at launch - base, community/mid, and loaded - and I fully agree with that.
One thing Ford did right was they didn’t gate Sasquatch behind the fancy expensive trims. I sincerely hope Scout does the same.
I believe a forged beadlock wheel is typically much heavier when you factor-in rings & bolts, plus you would be running bigger, heavier and less aerodynamic tires and less aerodynamic wheels (with the rings and bolts). I imagine that the range impact with Beadlocks would be severe?
