Harvester towing
mbeadnell
Jun 24, 2024
66
79
Upvote 13
The only disappointing thing about that video with Jay Leno is the towing limitation of 5K for the Harvester model. Unfortunately, that would be a deal-breaker for me as well.
Same. I reserved the Harvester because I want to use this vehicle for truck things and with the Ramcharger advertising 14k towing, Rivian over 10k depending on configuration (even though its a BEV), Scout would be starting behind the eight ball sort to speak if that was the case. I would have to cancel if it was any less then the 10k that was floated at the beginning and be disappointed in doing so.
It is pretty likely that while Jay had that limitation in the prototype, the production vehicle will be better. Those prototypes cost a lot of money, are metaphorically brittle, and aren't easily fixed or replaced compared to a production vehicle. I'm holding out hope for the production traveller with the harvester to be on the level or slightly surpassing all the other vehicles in it's class.
I came back to the forums hoping the 5k limit with the harvester was a joke. I for one will definitely cancel my Terra if that is the case. I was going this option thinking I would be able to tow near the 10k that was advertised at https://blog.scoutmotors.com/scout-traveler-and-scout-terra-revealed/. Nothing indicated that was battery only and it's detailed after the paragraph about the harvester.
I naively assumed that the harvester was there to keep the towing range up to par because many of the other EV trucks have great range until you tow and that has kept me away from them.
I know they have a ways to go and in this thread Jamie says 10k, I just hope they deliver.
Well I think the tow rating being lower on the harvester model can be one of two things or maybe both…
So if we use one of tesla’s as an example… their battery packs are not just a single large battery, its multiple battery modules wired together in series. So each module for example is like 5.6kwh @22.2v and can put out a continuous 225amps. Times that by 16 modules in series and you get 3,600amps which is about 1,278kw or 1700 hp. Theoretically that’s how much you could pull from that battery pack although you would drain that battery very quickly if you did so there’s a balance of economy and usability in there, now cut the modules in half to 8 and now you get 318kw or 416hp. That’s a significant loss in available power. I suspect this might be the issue depending on what they are using for a battery pack.
You also are possibly cutting the frame in the rear to fit an engine in there which could also limit the frames ability to handle more than 5,000lbs now. If that were the case then I could care less about a frunk. Put the engine where it’s supposed to be in the front and balance the weight in the rear with the battery packs and add a couple more to get that tow rating up to 10k. But they also are probably trying to save cost by not redesigning the front end
I think this is a pretty reasonable description of the challenges involved. I do think that the frame will be identical on both vehicles though. They would just loose too much economy of scale. Let's not forget the vehicles with the harvester are the default, the BEVs are the exception. One way around the issue of the limited battery in the Harvester'd vehicles is to tune the ICE engine for 2 RPMs. One would be at maybe 80KW for normal use, and the other would be at close to peak of the engine output. Yeah, it would rip through fuel and probably not even be able to keep the battery topped up while going up a long mountain pass, but I think (having done very little of the required math) that it could still surpass the other vehicles in its class/price-point. We'll have to see where this all goes, but these aren't n00bs building this truck.
From the information they’ve provided and what they want to achieve you can make slight assumptions. If they want 150miles from the battery pack and 350miles from the generator then you can assume they would only need 23mpg from the gas generator, which is reasonable considering how heavy they will be. You have to balance run time with fuel efficiency, because too much run time isn’t fuel efficient and puts too much wear on the engine, but also to little run time does the same thing. Much better than the ramcharger gas generator which would only be estimated to get 20mpg however. That also assumes the electric motors are getting 4.1m/kwh however, which usually isn’t the case for the heavier evs, but I feel like any good ev now is getting that sort of efficiency from their motors pair with regenerative braking.
Then for them to get 150miles straight battery pack I’m really assuming here but if we took the tesla ev battery packs for example then 150 miles at 4.1m/kwh would equate to a 36.5kwh battery pack 7 modules in series, which could get 224kw continuous or just 300hp… which is blah
I hope that last part isn’t true and battery packs have come a long way in getting more continuous discharge amps from smaller battery packs. But I know the tesla battery modules are some of the best too. If they are doing the REEV by default then I would be throwing the engine in front and installing a larger battery pack to get atleast 500hp continuously, I feel like atleast 600hp wouldn’t be asking too much either.
I agree with pretty much everything you're saying, so this is just adding to the conversation. No matter what they do, this vehicle will rip through fuel and battery going up a long mountain pass with a heavy trailer. The problem with the electric dive on these machines is that without variable gear reduction (gears), you can't just shift to a lower gear and go uphill slower, you have to have sufficient wattage to complete the task. Without the harvester piling on top of the battery that is a big ask on that smaller battery pack. I also don't think it's reasonable to expect 500miles range if you're on one of those "uphill both ways" kind of trips anyway (I'm not implying that you are expecting that). I personally would find it perfectly acceptable for the vehicle to have a "heavy towing" mode that gives up on being silent, reduces the expected range, and requires the battery to be charged to some minimum level along with fuel in the tank. When you tow something heavy, you already know that some concessions will need to be made compared to zipping around in an unladen vehicle.
Reactions: Badams
Yes of course I wouldn’t expect that 500mile range towing either. I just hope they give the harvester model sufficient power as I fear that it might be possibly underpowered. Now that I think of it however, 4.1m/kwh might be pushing it on a vehicle that size will probably be closer to getting 2 m/kwh as similar vehicles are also getting about the same so I could be completely wrong about that part. The ramcharger is using a 92kwh battery pack which is massive honestly the m/kwh comes out to like 1.5 on that truck which is terrible for being unloaded! It seem that we could expect the kwh to be cut in half when towing possibly more. The problem with evs is when the motor gets out of it’s efficiency range it’s really no better than any other type of platform.
Btw I’m not arguing at all. More or less just think out loud.
Reactions: bsddrake and Badams
. . . strongly suggest the harvester model towing more than 5k. This is going to be a deal breaker for most people and cause a lot of cancelled reservations.
Do hope SCOUT MOTORS is listening as I will have to switch to another brand ICE Truck model if the 5,000# is the final tow rating.
The sooner SCOUT MOTORS can clarify that specification the better.
Reactions: Munsterlander
Projected tow rating for the Traveler is 7,500 lbs. and and Terra is 10,000 lbs.
Final numbers for all models, including the EREV/Harvester models, will be announced as we get closer to production. Our teams are still optimizing everything and final numbers are still fluid.
As a customer most interested in towing campers, dirtbikes, other offroad toys i would love to see the Terra maintain that 10k rating - while not killing the range - hopefully the Harvester option solves this? Maybe Harvester Diesel option - there are some smaller 4 cylinder diesel engines in Europe that are interesting as well :)
The issue is Diesel Gate.
Also everyone complaining about the tow capacity for the harvester, go look at a bronco. They can only tow 3,500lbs.
Not an Apples to Apples comparison.
Bronco being a 'Jeep like' fun in the dirt vehicle while Terra is a full-size pickup with a few off-roading features
We have tons of data from other EV Trucks that show about how many kw/h it takes to tow 10k lbs at highway speed. It is impressively terrible (my wild guess is it takes about 90kw per hour to tow 10k lbs). The Dodge Ram Charger is being designed to be able to tow - but it has a huge generator in it (a large enough engine to power a 1/2 ton truck..., although not a quick or fast one). Since the Scout is still being developed - nobody has any hard data on what it will ultimately be able to do. The best we have is what they are designing it to do. Scout has been extraordinarily responsive to feedback. I am sure they are weighing plenty of options yet - and are mostly just bound by the laws of physics (and well, the laws of economics).
That all said, I don't know if the tech is really ready for a long haul heavy towing consumer EREV. Sure, we can make one - apparently Dodge is. But I think the compromises to make one will not help it any with market adoption. A long range towing EV will need smaller, lighter, cheaper, and higher capacity batteries. Putting in a full sized truck engine to make it happen is kind of the opposite of the best part is no part. Besides needing the complete ICE engine systems, it also needs a full EV drive train. Right now that is making it about 1 ton heavier than a normal Dodge 1/2 ton.
Throwing my hat in the ring as another person who will probably back out if the Traveler Harvester has significantly lower towing capabilities than the Traveler EV.
The whole point of the Harvester is that it solves the weak spot of EVs for road trips and adventuring: Range. EV range is terrible when towing. Travel trailers are heavy. If I'm towing one of those, I'm going long distances. I imagine I'm in the majority here for this fairly common use case.
The Traveler Harvester would be the ultimate adventure SUV and all-rounder if it can tow 7k. At 5k, travel trailer options are really limited and the value proposition is dramatically reduced.
Welcome to the community. The consensus on this topic is we just have to wait for more specifics to be released. There’s lots of info on the forum but some things just aren’t known yet it seems.
