Harvester towing
mbeadnell
Jun 24, 2024
51
70
Upvote 13
How do you know it caused a-lot of cancelations? only people that know that are Scott, and the rest of the team. Also No numbers are final yet, engineers are still hard at work.
This is based off numerous people who said this was a deal breaker both on this group and Facebook. I obviously cannot confirm 100 percent the follow through was there but is is concerning none the less.
People are very very quick to use words rather than legit actions when it comes to the internet!
It was a suggestion I made which is what this group is about. I was simply making suggestions based off information presented.
Fairly, it was a STRONGLY suggested which implies a very aggressive
I’m not getting the Harvester so I don’t care either way but ultimately, maybe Scott Keogh should have just kept that tidbit to himself if final testing isn’t complete. Case of “the sky is falling” reactionary syndrome
Strongly actually is not “aggressive” it simply implies a “firm” suggestion. It would be aggressive if used in bold or use characters such as an exclamation point…etc. I would not read to much into that. I do believe however if information is not concrete it should not be shared with public.
I'll say, I certainly had a moment of pause when I heard Scott say that Harvester towing was 5k. My Grand Cherokee has a 7,200lb tow capacity and I use it to trailer my old Wrangler on it's car hauler. I've always been told that you should not tow more than 75% of max capacity for long distances for safety, controllability and to leave room for cargo weight, which leaves me at 5,400lbs. Stock, the curb weight of my Wrangler with 4.0 motor and hard top was about 3,200lbs. I no longer have the hard top or doors, so that maybe drops to 2,900lbs, but add in additional cage weight, HD bumpers & tire carrier, winch, heavier aftermarket springs, transmission, t-case and axles and I'm probably up to 3,500. Plus estimated 1,600lbs trailer and I'm over 5k.
So in my case since I specifically reserved the Traveler Harvester with the thought that I could make the EV SUV jump from my current V8 SUV, now I'm not so sure. Next time I'm trailering the Wrangler, I'll swing by some scales and see how it adds up.
My Wrangler weighs just about 4k and an aluminum trailer puts my total a bit over 5k. Even my V6 Grand Cherokee has a 6,000lb tow capacity. I was really hoping to replace the GC with an electric SUV that could tow my LJ to my wheeling spots. The range drop with pure electric won't allow that since I'm not adding an hour charge in to my drive every 100 miles. The Harvester was supposed to solve the range issue, but 5k pounds just replaces range with a capacity problem.
Projected tow rating for the Traveler is 7,500 lbs. and and Terra is 10,000 lbs.
Final numbers for all models, including the EREV/Harvester models, will be announced as we get closer to production. Our teams are still optimizing everything and final numbers are still fluid.
Thank you for replying to these threads. Bet you never imagined just one comment would receive this much attention :LOL:
You and the team have obviously seen the feedback on the 5k number. Hopefully you all can find a way to get that number up some.
We would like to eventually tow a pebble flow camper with the traveler harvester model. Definitely need the 7000 pound towing capacity. A “heavy duty” model that can tow farther distances would be ideal.
BlueRidgeTraveler:
Agree!
I think the Pebble Flow is 6800 lbs loaded so 7,000 lbs and tongue weight of 10% would work. Unfortunately, with a Harvester we're told it's 5,000 lbs.
Lightship is even more at 8,300 lbs fully loaded. So, only Terra BEV could do it and then, maybe, if the self propelled versions of these two RVs are purchased for additional money, then the Terra could approach the 350 mile range, allegedly, before real world testing.
Then, you have to find a way to charge both the Terra and the RV while on a long road trip. The solar panels on either the Flow or Lightship just aren't enough while traveling.
Hopefully SM's Comes through or its RAM Charger with having to deal with dealership nonsense, etc.
Also, Its clear at least Jamie at ScoutMotors is paying attention and understands the concerns and how it may effect actual completion of reservations to orders.
More choices are coming that will eclipse SM's offerings if they don't adjust to the needs of those of us most interested in the very scenario you describe!
Cheers
L
I would strongly suggest the harvester model towing more than 5k. This is going to be a deal breaker for most people and cause a lot of cancelled reservations. My opinion but I would not have announced something like this without all the details In place to make a firm stance. This has created a lot of confusion and speculation and as a result many cancelled reservations. I would like to see the Terra at least able
My brother in Scout,
I'm also just adding my name to the general statement that 7500lbs should probably be the minimum. At only 5k, this thing wouldn't be able to tow a friend's cybertruck to a service center, lol.
How would you even tow a Cybertruck it’s a brick wall, and when you go to tow it it’s aluminum casting will snap in half.
