Charge port at front, passenger side
SpaceEVDriver
3,381
13,083
Arizona
Please don't fall for the hype about the rear driver side being the best place for the charge port. It's far more useful to have it at the front passenger side.
It still makes it easy to use the NACS chargers with their super short cables. With it being in the front passenger, only one NACS post is used while charging, and it also enables charging without always having to drop a trailer. A rear port makes towing a far more painful experience. For a vehicle with towing capability, a front positioned port is best. For a tow vehicle with a NACS port, the front passenger port is the only sensible position.
Upvote 9
DCFC charge times right now are 20-45 minutes; I'm typically back on the freeway within 35 minutes with my "slow" charging Fords. This is often after being threatened with idle fees because the vehicle reached the max charge I set. Some vehicles can hit 10-20 minutes for the standard ~80% refill with the right chargers.
But it should be noted that the vehicles on the road will not improve substantially in charge times because charge time is dependent on battery architecture coupled with charger architecture. Many CCS1 fast chargers provide more power than most batteries can accept, so often the limitation is the battery, not the charger. But the majority of NACS chargers (brand-T supercharger) can only supply up to 600 volts (or lower), which means the Scout will not see a benefit from charging at most *existing* NACS chargers compared with, for example, an EA charger CCS1 (or converted) that provides 350 kW of power. Maybe in three years that will have changed. We'll see.
Audi includes a second charge port on select models. Perhaps engineer the Scout to support two charge port locations and give the buyer the option to select the base port's location along with giving the buyer the option to upgrade to two ports?
But there really isn’t an industry standard, there are cars with ports front/back, left right and center. This is really only an issue for older Tesla chargers because they have very short cables. Everyone else, even newer Tesla chargers have cables of sufficient length that it’s really not an issue. Like the op, if you want it to work well at a Tesla v3 chargers, front right is a great option.
We don’t have to everything the way Tesla does it just because Tesla does it that way.
And now we know why - https://electrek.co/2025/01/31/tesl...e-to-elon-musks-garage-layout-says-lucid-ceo/
I’m conflicted…don’t know exactly where to place my vote on this subject. Here are some rambling thoughts:
I back in virtually everywhere for a multitude of reasons, but mainly because it’s safer as well as being easier for me. You can’t see all that well in many situations when trying to back out of a space (it’s better these days though with cameras and sensors of course but I don’t fully rely on those), however when you arrive and back in you’ve already surveyed the area coming in so there’s no mystery and then later on it’s easy to see everything around you and just pull out to leave. So, I would prefer back in charging spaces. Especially if I have to sit there for 40 minutes - I’d rather not stare at a building, fence, chargers, etc.
On the flip side, I tow often enough that I’m concerned with where and how I would charge on road trips. I’m not really interested in dropping the trailer to charge. I’ve watched it done at Superchargers a few times. What a pain. It’s already going to be more inconvenient than filling up with gas on long trips and I’m not wanting to make it even worse when towing, so I’m hoping that there will be better infrastructure by the time I have my Scout.
I’m not really a fan of pulling in with a trailer to charge at a regular charger either. There aren’t many chargers anywhere near me, but the ones that are within say 100 miles or so - at all of them I would be blocking the driving lane if I just pulled forward into the charger with a trailer.
Anyway, like I said I’m torn on this one at the moment.
For towing is a must
I’ll say it again - I have not seen a bank of chargers in person anywhere at which you could pull in while towing a trailer to charge and not block a driving lane with the trailer. At many chargers it’s not even feasible to get a trailer in there by pulling in due to the tight spaces they’re located within. Just my two cents…
It will be really interesting to see over the next three years if truck stops start getting pull through EV charging in the truck parking area. And if Tesla improves their network from 250 kW so that if we do have to unhitch at least we get 350 kW or better at more places. And if EA and others build out their already 350 kW networks faster.
