Thoughts on Factory 37s
I suspect it will be treated like the Bronco Squatch. Broncos got the 35’s with all the suspension changes and I suspect scout will do that with 37’s then set the general suspension to handle 35’s and 33’s. But as I’ve learned here and on the Bronco forum a number of years ago already is everyone who off-roads has their ideal idea of what makes a great set up. The 37’s package will be just as much for macadam masters who want the look bs true off road enthusiasts
Jamie commented on this in Post #16
Reactions: THil08 and maynard
Forget 37’s - we want 40’s! :ROFLMAO:
Yeah, no.
There aren’t very many stock/from-the-factory vehicles that can accommodate 37” tires.
  • Ford Raptor Bronco and Wild Track
    • From the factory
  • Ford F-250/F-350 Tremor
    • Only certain tires will fit without modifications
  • RAM Power Wagon
    • Rubbing of most tires on various suspension parts at full turn or full stuff
  • RAM TRX
    • Most tires fit without modification, but some can rub
  • Jeep Wrangler and Gladiator Rubicon
    • Needs modifications like wheel offsets and bumpstop modifications to stop from rubbing
Pretty much every other mass-produced vehicle would need modifications such as removal of firewall materials, sheet metal modifications, potentially removal of safety features such as the “crash bar” that stops the tire from entering the passenger space during an accident, and, of course, lifts and wheel offsets.
Because of the underbody construction of most vehicles, a lift on its own doesn’t raise the lowest point of the vehicle, which is often the at the control arms or the differentials, so the vehicle’s true ground clearance doesn’t increase with a lift, it just allows larger tires to be installed, which is what increases ground clearance.
If Scout could have the same ground clearance as the Rivian then the only reason anyone would have to run 37s is for looks.
I love snorkels!!
Probably not gonna look right coming out of the butt end of my Traveler for the Harvester engine... :ROFLMAO:
That does make me wonder though, with the Harvester mounted so low, what impacts will be had on the wading depth? Wonder where the plumbing for the air intake will lead? Hopefully somewhere high!
Oh I’m just in it for the looks. It doesn’t have to be connected to anything. 😹
That is a very good question. :unsure:
Wait - I forgot what we were talking about...
Oh yeah, 37s... too big for me, but I'm loving the looks with 35s. I squeezed 33's onto my Xterra with very minimal mods (just changing the shape of the fender liner slightly) and other than feeling a bit slower off the line, have had no downsides. But that was only going up one size, from 265 to 285.
And yay for snorkels! Sometimes you do things just because you want to and it's on sale!
No rubbing with the 33s on the Alpine Loop last summer, here's a poser shot showing stuffed 33s and the unnecessary but cool to me snorkel
This is the only kind of snorkel we have ever used. The one my wife prefers. 🤣
@speedrye You will not need a snorkel for the Harvester. You only need a snorkel if vehicle needs to run the engine while in water. Since the Harvester is a serial hybrid, you don't need to run the engine all the time. You'll just need an air intake that prevents water from getting in; you can drive the Scout through the water on battery power alone. As long as the air intake can prevent water from getting in, it doesn't mater how low it is.
@cyure If I remember correctly, you switched to reservation to pure BEV. So you can put the most awesome looking (non-functional) snorkel you can find on your PBY Traveler. Just make sure your husband takes lots of pictures so you can post them here. :LOL:
You remember correctly! 😹
While you don't need to run the harvester in water - it would still need to be designed so water does not seep in and mess things up. IIRC when things have air inside and get hot - they usually have to vent pressure. Dunk them in water - temps drop, they are going to want to suck air in to equalize the pressure. Not good if they are not sealed right and the vent is under water.
