From Google:
Compare travel time and cost from Missoula, MT to Anacortes, Wa in a Scout Terra Harvester vs Scout Terra EV vs Ram TRX. Average cost of gas is $5.638 per gallon. The TRX will average 14.4mpg
To compare these three trucks for a trip from Missoula, MT to Anacortes, WA, we'll use the standard route along I-90 W and I-5 N:
- Total Distance: ~535 miles
- Base Driving Time (No Stops): ~8 hours 30 minutes
Baseline Assumptions & Data
- Gasoline Price: $5.638 per gallon
- Electricity Cost: ~ $0.15/kWh (home starting charge) and ~ $0.48/kWh (DC fast charging on I-90/I-5 corridor)
- Ram TRX: 14.4 MPG average (uses gas for all 535 miles)
- Scout Terra EV: 130 kWh battery (~350 miles EPA estimated total range; target consumption ~2.7 mi/kWh on highway)
- Scout Terra Harvester (EREV): ~65 kWh battery (~150 miles pure EV range) + 4-cylinder gas generator yielding ~350 miles on gas (targeting ~25–28 MPG equivalent once running on gas)
1. Cost & Travel Time Breakdown
Metric Ram TRX Scout Terra EV Scout Terra Harvester (EREV) Fuel / Energy Used 37.15 Gallons ~200 kWh 65 kWh (EV) + ~13.8 Gal (Gas) Fuel / Charging Cost $209.45 $79.80 $87.61 Charging / Refueling Stops 1 Stop (5 min) 2–3 Stops (~70–80 min total) 0–1 Stop (~5 min) Total Travel Time ~8 hours 35 mins ~9 hours 50 mins ~8 hours 35 mins
2. Vehicle Breakdown Details
Ram TRX
- Fuel Consumption: 14.4 MPG535 miles=37.15 gallons
- Total Fuel Cost: 37.15 gal×$5.638/gal=$209.45
- Time Impact: Minimal stop time. One quick 5-minute splash-and-dash fuel stop is sufficient, adding negligible overall time.
Scout Terra EV (Pure Electric)
- Energy Consumption: Starting with a 100% full battery (130 kWh) in Missoula. Highway driving (~70–75 mph) will consume roughly 2.2–2.5 mi/kWh, requiring around ~200 kWh total.
- Full home charge before departure: 130 kWh×$0.15/kWh=$19.50
- DC Fast Charging along I-90 (~70 kWh total needed): 70 kWh×$0.48/kWh=$33.60
- Total Cost: $79.80
- Time Impact: Requires 2 to 3 fast-charging stops (e.g., Coeur d'Alene, Ellensburg) averaging 25–30 minutes each. This adds roughly 1 hour 15 minutes to 1 hour 20 minutes of dwell time.
- Energy / Fuel Consumption: Starts with a 100% charge (65 kWh) for the first ~150 miles. The remaining ~385 miles are powered by the gas-engine generator. Assuming ~28 MPG efficiency from the generator: 28 MPG385 miles≈13.75 gallons.
- Full home charge before departure: 65 kWh×$0.15/kWh=$9.75
- Gasoline: 13.75 gal×$5.638/gal=$77.86
- Total Cost: $87.61
- Time Impact: With a combined ~500-mile system range, you can complete the trip with either zero fuel stops or a quick 5-minute stop near the end, keeping total travel time matched to the TRX.
I've been MIA for a bit because reasons, so I missed this thread.
Chiming in for some context.
Frankly, I think the estimated efficiency of the Terra and traveler is a too optimistic. I see it listed both as 2.7 miles/kwh, and then as 2.2 - 2.5miles/kwh (not sure which is actually being used in the maths though). I were doing estimates, I'd be using something lower. Maybe 1.8 - 2.3miles/kwh or something like that. At least until we get more data.
I've done part of this drive (about 100 miles IIRC) 7 times this summer (we peel off and head south at ellensburg to head to UT, and we're 3 full round trips and 1 trip half done atm, hence the uneven number of trips). And much of the rest of the trip we do is quite similar as well (spanning OR, ID, and UT, in similar terrain and speed limits between 70-80mph).
I've done the trip twice in our Ioniq 9 (3 of those trips through that I90 corridor and up towards anacortes). The best efficiency I've seen is in the ~2.6 miles/kwh range. This was in the summer, on the downhill elevation side (UT > WA). The worst is 2 miles/kwh. That was in the cold (~33-45f), with a bike rack on the back, at 75mph.
More data in the thread here (which you probably saw, but putting it here just in case).
So, a lot has happened. Too much for any reasonable summary. Life has been a lot lately.
I've got more detailed information for people that want it, but again, summary.
But here are some cliffnotes:
We've are now on our fourth road trip this year. As a reminder, these are ~850-900 mile road trips, in a single day (WA/UT).
We took the Ioniq 9 Tucson PHEV twice, and the Ioniq 9 twice. So we've had the chance to do some comparisons between the two, and I thought I'd share a summary of the feelings on the comparison.
High level:
High level:
- BEV road tripping is without a doubt, more time...
Admittedly, the Scouts might have more efficient motors and inverters or something like that. But body size/tire type data alone would suggest that all else being equal, I'd guess that our Ioniq 9 would be more efficient at speed (more aerodynamic, lighter weight, and has more street oriented tires, with lower ground clearance).
I do think your recharging times are pretty accurate though. Assuming that the Scout is an improvement over our Ioniq 9. We recharge our ~106kwh battery pack from ~10-80% in about 23-25min. And as charging stops are still relatively sparse through rural ID, we are usually going a bit over 80% to get some buffer for the next stop, so ~25-30min sounds about right.
