Seattle Scouts
Is anyone else on here a customer of Seattle City Light, or really into the bi-directional charging stuff? A few years ago, we installed solar panels. As part of the project, we also switched to gas on-demand water hearing, a whole house electric heat pump and got an induction range. We also have a 2019 Kia Niro PHEV. For anyone interested in electrification, my advice would be to switch out your 'plant' and use it for a year before you try to size a solar system. We went from covering 102% of our projected annual load to just about 89%. Still great, and we're happy, but adding a 2nd BEV or whatever you call the car with the Harvester option (EREV?), will likely take us down another 20% or so?
Anyway, I've always been interested in the whole house battery back-up. It's actually kind of silly in Seattle since the area that I'm in rarely has outages and most of our power comes from firm, clear hydropower. Still, there's always the BIG ONE that's looming on the time horizon and who know what the future holds when our robot overlords finally rise up and takeover. So, the appeal of a giant battery on wheels to give me DAYS of back-up over the exorbitant cost of home batteries is great... but my understanding is that you need some kind of battery on site to provide the 'reservoir pressure' to your own little microgrid. At some point I'll need a battery if I want my Scout to back-up my house.
I've priced out a couple of options, but when we got down to it, the big problem was siting the home battery. If we do it outside our house, then we've got the eyesore of a mini-fridge we have to look at in the back yard. If we do it in our garage (which is right below our living room), I'll need to switch out the drywall from 1/4 to 5/8 to meet fire code. That project alone is close to 8K.
I'd love to connect with folks in the Seattle area who might be into gaming this out and talking about different concerns or ideas.
I’m not in the Seattle area, so can’t answer regarding the specific utility.
However, I’ve installed more than a few solar systems. Two for myself and several for others, grid-tied and off-grid.
Without knowing all of your intentions, here’s a broad overview:
You don’t need a secondary battery to make use of your BEV. You do need some mechanism for pulling power from the BEV. That can be a bidirectional charging setup, which can get expensive. It can be using a 240 V outlet in the vehicle (the Lightning has this, for example). The Lightning’s bidirectional output is limited to 40 Amps, 240 Volts, or 9.6 kW. The Lightning’s 240 V outlet in the bed is limited to 30 Amps, 240 Volts, or 7.2 kW. This is going to be similar for other vehicles. If you use the 240 V outlet, it’ll be treated as a generator for the purposes of connecting to the house. An electrician can help with that set up. It’s not (necessarily) automated. The bidirectional setup is automated only if the vehicle is plugged in when the power goes out.
For cost savings and reduction in emissions, a whole-home battery is the quickest and cheapest way to go. No solar. Just a battery that’s large enough to cover four to six hours (or more) of usage. This helps flatten out the duck curve (peak demand from about 3:00 PM to about 8:00 PM, depending on the specifics of your community). You would set your battery to recharge from the grid during the lowest cost time of day. If your utility charges extra for use during the peak demand, a battery can quickly reduce your monthly bills. You can use the BEV for this in one of the two ways I mentioned above. If you use the bidirectional option, you’ll need to have some kind of non-outage trigger to tell the BEV to take over during the specified times. I don’t have a bidirectional system, so I don’t know if they come with that kind of time-based trigger. I would imagine they do. If you’re using the 240 V plug, this is a manual action and you just have to remember to plug in, switch the breaker, and then undo all of it when you need to.
With solar, you can use the solar either independently, with a whole-home battery, with the BEV, or with all three. You can also get an EVSE that uses your excess solar to charge your BEV, if it’s home during the times when you have excess solar. This is a more costly solution, but it does offer some benefits not attainable without solar, especially if paired with a battery. Specifically, solar+battery offers longer-term cost savings and longer-term outage resiliency.
Ok, for those of you who don't live in Washington state... consider moving along to another forum. This post will not matter.
There were two different bills in the Washington legislature last session. One was Senate Bill 5377 and House Bill 1721. I think neither of them made them out of committee. The next legislative session starts in January, but the prefiling for bills starts December 1st. I'll try to keep folks up to date so we can make sure these bills get re-filed for the next session and hopefully get out of committee.
I strongly believe that everyone intending on purchasing a vehicle in the future that this will matter. These state franchise laws are outdated and are in place to protect the dealerships. I get that, but car dealers near me are not financially struggling and typically the owners own several dealerships in the Southeast and several brands of vehicles and continue to grow unchecked. Some of these large dealerships showed up for the South Carolina preliminary hearing which stalled right out of the gate. These guys sounded as if they were starving...don't get me started again.
On the flip side, there is not much to protect the consumers from these greedy dealers and for the laws that are in place, they find workarounds. Hopefully, Scout Motors will find similar workarounds to the SC franchise laws.
Best of luck to Washington state and others that are fighting these laws. Consumers need to be holding their governments accountable to being swayed by lobbyists and dealer organizations while ignoring those who vote them into office. Write to your congressmen and congresswomen. There are some forum topics related to SC Consumer Freedom that may help. The forum Search tool is your friend.
For the past couple years, my wife and I go to the screening of the Warren Miller movie at McCaw Hall. It was great to see Scout Motors as an official sponsor of the tour. I'm looking forward to the 2026-2027 movie when we might all get a chance to win a Scout (or maybe just some Scout Beanies/Tooks).
Looks like the passes are going to get whomped ahead of the Thanksgiving holiday. Travel safe and Happy Thanksgiving!
The Washington State Legislature began their 60 days session earlier this week. The Senate bill and the House bill I mentioned in the post back in October have been reintroduced for the current session. They are now both in committee.
My suggestion would be for Washington residents to use the links on those pages to identify your support for these bills to their respective sponsors. I'll try to monitor to make sure that if they have a hearing, we can organize to go and show our support.
100% submit your support so we can get direct to consumers in our state!
It’s great you guys are staying in tune with this.
I have a general concern though reading the bill. It says EV only with specific language not allowing exhaust emitting vehicles to be sold so looks like if it passes only the BEV’s would qualify for DTC ??? Curious how they handle the other 60% of their vehicle sales?
None of the legislators I contacted yesterday have written back, but I think that's a good point. I think originally this bill was basically just some copy-pasta from what they used originally to allow Tesla to sell in Washington State. They tried to keep it super narrow to appease the Franchise Dealers Association, I think this bill was basically trying to leverage the support of the last bill to win more support, but maybe we can lobby for a revision to the text to allow for some sort of additional condition that if the exhaust from the motor doesn't power the drivetrain directly, or maybe even more broad that it would allow DTC for any car that was considered an BEV, EREV, or PHEV. @Scount Motors (@Jamie@ScoutMotors)? You guys got any guidance on this?
Ok, Senate Bill 5592 is the "EV" bill and 5377 is the 'pro-dealer' bill. You can watch the hearing they had on it last year:
Skip ahead to 1:03:30 to see the testimony of the competing bills. Note that at the end, they read out the support for the different bills. We need to write in to change those numbers for the 2026 session. There's a good explanation from the bill's sponsor at 1:09:23 about where she is trying to go with these biils. Testimony ends at roughly 1:32:49
