Are you sure about going 75mph on highway would cut the range near half? Then adding a 3,500 pound trailer it is cut in half again?Keep in mind the ranges quoted are usually accurate around 35mph. So a 400 mile range EV will only go about 200-220 miles at interstate speeds.
EPA range number is 55% City /45% highway.Are you sure about going 75mph on highway would cut the range near half? Then adding a 3,500 pound trailer it is cut in half again?
Its the same thing they do for Gas cars. I wonder if Scout already has factored in the EPA test into the range to give use the respectable range.EPA range number is 55% City /45% highway.
Here's How The EPA Determines EV Range
But it is understandable, so dive in and let's get your versed in regulatory language. But it is understandable, so dive in and let's get your versed in regulatory language.www.thedrive.com
It seems to depend on the manufacturer and how you drive it. I've seen highway tests of the ID Buzz that were way lower on pure highway, but exceeded the EPA number in City driving. There are so many variables. Of course a VW van is a giant brick and driving 75 mph doesn't do wonders for range. A Scout with 33-in off-road tires will probably lose at least 40 mi of range just on tires alone.Its the same thing they do for Gas cars. I wonder if Scout already has factored in the EPA test into the range to give use the respectable range.
35 inches* not to be nitpicking. It may lose 40-50miles, but also we have no idea how Scout engineers have software optimized for the size of tire. Rivian gets close to 330 on the large battery but 350-400 on the Max Battery. We also don’t know what type of battery Scout will be using in the battery pack.It seems to depend on the manufacturer and how you drive it. I've seen highway tests of the ID Buzz that were way lower on pure highway, but exceeded the EPA number in City driving. There are so many variables. Of course a VW van is a giant brick and driving 75 mph doesn't do wonders for range. A Scout with 33-in off-road tires will probably lose at least 40 mi of range just on tires alone.
Rivian seemed to find a way. Im sure Scout will too.Off-road tires get poorer fuel economy because of the aggressive tread and higher rolling resistance. Software won't change that. Improvements will come from the tire manufacturers. I'm sure they are working on it, but for now off-road tires=poorer range.
I have those same BF goodrich tires on my Chevy Silverado. No difference in range from what i was able to tell and it was coming off of street tires on to Off road.
They do have smaller wheels but they did talk about the Over The Air Update that improved range.
You’re acting like i have zero idea what bro is talking about. Trust me i know about range, tire compound, battery tech. I come from race car engineerings and moonshine runners. My Silverado took no effect to MPG when i went with larger rims and off-road tires then its stock street tires.I think the point they're trying to make is that no matter what battery tech, pack size, or whatever we're talking about, it is likely that the best range, will always come from the specs with smaller, more road-oriented wheels and tires.
Now, the total range could be more/less than what we've been told before, as the pack sizes, or other things could change. But bigger/wider/heavier tires, are always going to be less efficient in the EPA tests.
Same thing happens with my Jeep, when I went to bigger/stickier/offroady tires, I saw an mpg hit. Just how it works.
Also the BF Goodrich KO3 tires are become more of a hybrid tire as the generations move foward.
More efficient motors and batteries will come out and trust me it will make a difference. Look at the first tesla compared to Teslas of today range difference is huge. Because of new battery tech and motors.
Peace Out.
Other test suck so much they aren’t even realistic. EPA by far wins. BMW gave up on all those test. Thats why the 0-60 figures are always worse than what they always are. And why MPG are always 6%higher than whats given. We do our own testing. Only testing BMW doe stake place in is obviously the CO2 emissions test. Everything else is in house.Fwiw, I wasn’t trying to step on any toes here. Just thought I saw a misunderstanding, and tried to clear it up, that’s all. No personal slight intended.
Personally, I’m sure whatever estimates scout has given us so far, are already their best guess at EPA ranges, using whatever battery/motor/whatever technology that will be available/used at the time of release (ie, they were best guess projections/estimates).
I’m hoping that the real world range is close to the EPA range as well. It drives me sort of nuts when there is a huge gap between advertised range and actual range (Tesla recently had to lower their range advertised ranges across the board actually).
And as bad as the EPA test is, the t seems more realistic than the other tests out there (WlTP, NEDC, the china one… CLTC?).
And here I thought FORD was the only funny acronym ?Other test suck so much they aren’t even realistic. EPA by far wins. BMW gave up on all those test. Thats why the 0-60 figures are always worse than what they always are. And why MPG are always 6%higher than whats given. We do our own testing. Only testing BMW doe stake place in is obviously the CO2 emissions test. Everything else is in house.
TESLA is like what i said earlier in a thread. They are the biggest scam in history Range is always over exaggerated, they are priced as if they are a computer and not a car. Because TESLA has been called a AI learning company by Elon on a podcast. Its a Huge scam. Elon is a great mastermind but TESLA(Totally Electric Still Lame Anyway) is a scam.
NOT SCOUT though they are definitely not lame! With the rich history And Range extender make it by far the best EV coming to the market.
My guess is it will be a low to mid compression, naturally aspirated configuration. So, probably regular.What gas type do we think will be used Regular or Premium?
I'm certain it won't. Not sure what that statement was about, probably just pulling numbers out of thin air.Are you sure about going 75mph on highway would cut the range near half? Then adding a 3,500 pound trailer it is cut in half again?
