Is there anything SM could offer to get you to switch from EREV to BEV?
Well now here’s the next question. Since there’s an engine would they use the heat from said engine to help heat the cabin or no because it might not be running all the time?
It doesn’t take much to build a basic a logic check in that says something like, “if the engine is running, use its waste heat; if it’s not running, use the heat pump; if you need more than the heat pump can generate, then start the engine.”
