Traveler 240 outlet
LRK
Jan 22, 2025
4
11
Michigan
This is what I sent to Scout support:
I just do not understand why you would not place a 240 V outlet in the Traveler. You are placing a 240 V outlet in the pickup truck. I would think the batteries are comparable, the wiring systems as comparable, and the control systems are comparable on both vehicles. The minimal cost savings cannot be the justifiable reason to intentionally make the traveler inferior to the pickup truck.
It just appears to be a knee jerk, ridiculous, penny-pinching decision that auto companies always make. Don’t make a great product into a good product, a good product into an average product, an average product into a poor product; only makes a company go out of business. Don’t start Scout with this business plan.
I think you should reconsider this decision. It’s not as minor as you think.
This is what I received:
Thank you for taking the time to share your perspective so thoughtfully. We hear what you’re saying about the difference in outlets between the Traveler and the Terra, and we appreciate you calling it out.
At this stage, our current plan is:
  • Traveler SUV: USB‑C and 120V outlets throughout the cabin and storage areas. [1]
  • Terra pickup: Two 120V outlets and one 240V outlet in the pickup bed, intended for heavier tools or appliances.
Both vehicles are still in the pre‑production phase, and many specifications are still being refined. Final details are not confirmed until closer to production, and some features may continue to evolve as development progresses.
Your feedback about the value of a 240V outlet in the Traveler is genuinely helpful. We’re actively listening to input from our community, and you’re welcome to share this directly with other owners and enthusiasts on the Scout Motors Forums: https://scoutmotors.community.forum/.
Please let me know if this helps or if you have any further questions.
If anyone feels that leaving out the 240 V outlet is important; I think you should let Scout Motors Inc. know. I think they are making a huge mistake.
Upvote 4
Welcome to the community!
I’m going to take a bit to think about your suggestion and then circle back to comment/vote
I'll definitely agree with wanting the 240v in the Traveler as well, but it mostly depends on the vehicle to V2H or V2L capabilities. I want to be able to use my Traveler as a battery backup and generator for power outages, and without 240v, that won't be particularly useful. It's a feature that doesn't cost Scout anywhere near as much as it saves me in home battery and home generator costs, so having 240v access is a big value-add to me.
Would people be willing to accept an 30amp 240V outlet that required plugging into the charge port? Or does it have to be a separate outlet in the vehicle?
For example, I have the OEM V2L adapter for my Ioniq 5, which gives me a 15amp 120V outlet via the adapter in the charging port. I am fine with that. I don't need an outlet in the vehicle since I can get it with the adapter. A lot of other BEVs provide AC power vi an adapter as well. If the Scout's charge port was designed to support a V2L adapter that can provide 240V, then I would prefer that to having outlets in the truck.
I'd be perfectly happy with a charge port adapter.
Why compromise. The scout pickup already has the engineering in place. Scout recognized the necessity. It seems very shortsighted to make a compromise of a 30 amp, and in the line connection on everything is in place.
The difference there is the 240v is in the bed wall, not under the exterior cover and there is more space. Not against it but if being honest, I don’t need it either so wouldn’t want to pay more. If easily optioned that would be great. I’m sure primary goal was work trucks for construction-I realize lots of other options for using it but this was probably the primary reason. Being on a job site pre electric service makes this a great tool in a pick up. Framers running air compressors for nail guns would be so much better. But I suspect most would likely do a Terra with cap to have best of all worlds? Just my thinking-but valid nevertheless
I’m a fan of the 240 V outlets on our Silverado and previously on the Lightning, but its utility is greatly reduced if it’s inside the vehicle instead of external. If the charge port with the other receptacles can handle the size of a NEMA L6-30R, that would be ideal.
Yeah, we've been through this a few times. I think they haven't done it due to design/real estate on the left rear of the Traveler. I would really like 240V/30A capability so I could power my house in an emergency (I do not lose power enough for the $10k integrated system like Ford has) but I am fine with an adapter that plugs into the charge port. Hopefully that can be done.
If for no other reason, it would be nice to have 240V to emergency charge another Scout community member's Scout if they're stranded. With 120V as the only option, it's going to be a long wait.
I have a 2020 Nissan Titan and have an option for power plugs. I can see where the 240 could be used by a hardcore camper that might have some tools they would use out in the field that need power. Carrying portable power stations and solar panels can be vexing to move and arrange.
