Solar Tonneau option
philipsmithj
Aug 5, 2025
5
Amonst the solar suggestions, I'm not seeing the suggestion of using the bed space on the Terra. A factory integrated solar tonneau or shell could basically provide off grid power. The huge attraction to this product aside from being American made is it's "multi-energy/fuel" options, especially for any off-grid, away from civilization activities. Not to mention, my car is all but forced to be outside the majority of daylight working hours. Why can't it charge without being tethered to a charging station? Looking at home panel standards by sqft, I'd bet there's around a 1Kw capacity if you could work out the roll or I guess in this case, stack away capability for when the height is needed for loads. Could it fold away between cab and bed or be at the front of the bed (it would need to be protected somehow). Solar paint and tint are very cool options, but seem very difficult from an engineering perspective. A solar sunroof or tonneau cover seem way more feasible. If you go with it, you *could* call it the Smith cover ;). (Microsoft has been commenting suggesters names into their code now for years. It's a good incentive for free suggestions) I'd definitely be a proud owner.
Where and when I go truck camping (to spring ski in the NE) would give me such little solar power, I would not be able to justify the investment (at least here). And it is usually just a 1 or 2 night overnight if/when I can do it and the WX, snow and avalanche forecasts are all in agreement. If I were camping in a desert for a week straight multiple weeks a year, maybe.
They make a 1 kW option for the lightning if I remember correctly. Probably the easiest application would be to have some sort of solar charging receptacle inside the bed. But if they engineer it correctly, it would be natively transferring power through a series of metal connections I would imagine
The SOLIS tonneau cover is such an offering. For an 8-foot bed, they suggest they can install a tonneau with 650 Watts of (ideal) power. To charge the vehicle they also need to have an auxiliary battery that powers a Level 1 EVSE. So the system works like this:
Solar —> Auxiliary Battery —> Level 1 EVSE —> Vehicle.
(Not coincidentally, this is how my system works, but I do my own solar instead of a tonneau cover.)
Ignoring losses, we can calculate how much an idealistic situation would work out:
In the United States, the average useful solar input is 4 hours per day. Obviously this is average, not every day. Some days will have more, some less. Some areas will have much more. Let’s use the national average of 4 hours per day.
650 Watts * 4 hours/day = 2.6 kWh / day.
365 days / year * 2.6 kWh / day = 950 kWh / year.
We expect somewhere between 120 and 180 kWh in the BEV. I think it’ll be closer to 150, but I don’t really know. I know they’ve said some numbers, but I’ll hold of on being certain. Let’s use 150 kWh.
949 kWh/year / 150 kWh/charge cycle = 6.33 charge cycles per year. ***for an 8-foot bed***
Assuming the 350 mile estimated range is accurate, that’s 2200 miles per year gained from the tonneau cover. ***for an 8-foot bed***
With a 5-foot bed, you get 5/8 or 63% of that. 6.33 * 0.63 = 4
63% of 2216 = ~1400 miles/year.
Cost considerations, if that’s the reason you would consider it:
Assume you’ll get a tonneau cover anyway, the decent ones are about $1500.
The SOLIS isn’t in production yet, but I would look at Telo’s suggested price for their factory-provided solar tonneau cover, which is $1500 more than the non-solar version. The bed is 60” long and 73” wide, so slightly smaller than the Terra’s bed. Let’s round up to $2000 (more) for the solar tonneau vs the non-solar tonneau. However, that doesn’t include the cost of the battery. Add another $2k for that.
For the first year, you pay $2.85/mile gained (in somewhat ideal conditions for the average US resident). But after the second year, the cost of the tonneau cover drops to ~$1.40/mile. After the 10th year, it drops to $0.29/mile. This is significantly more expensive energy than what you usually get. I pay about $0.02/mile for my Lightning when using grid power at home.
I don’t think the SOLIS auxiliary battery is close to the right size and would upsize to at least 5 kWh, so that would add cost.
Some people would argue that’s not worth the cost. Of course, some of those people would spend $5k on wheels and tires upgrades that they’ll never make use of or some people will spend $10k on an extended range battery but won’t take the truck on a road trip. What you spend your money on is up to you, so I wouldn’t let people use the cost argument to dissuade you from getting what you want to get—unless they know your financial situation and you’re planning something truly foolish.
I use my system to extend the range while I’m camping. I can get about 30-50 miles extra range—depending on the specifics—while boondocking for a long weekend. This enables me to get to some of my favorite camping sites that are just out of range of my 320 mile Lightning. But I’m in the US desert southwest where we get 8+ hours of good sun in the winter and 14 hours of good sun in the summer. It isn’t about cost, but about enabling something I enjoy doing: getting far from civilization. Even an extra 15-20 miles farther is a bonus and is worth it to me.
That’s a lot of math . . .
Scout would be much better served through a partnership, as opposed to trying to do this themselves. Perhaps a partnership whereby they co-brand a solar solution with an industry leader (for example). Please do not take this on yourself Scout! Stay focused on the core competencies required to be an EV OEM - particularly since warranty, service and support requirements will all need to be very focused coming out of the gate. It will be super important for Scout to eliminate as many distractions from the core as possible.
Amen to that.
The solution needs to be more than just a solar cover on a bed. It still needs integration into the vehicle's inverter and battery.
I ask a lot of questions around here lately.
To all of you asking for an integrated solar solution, if SM does not do that and you have to go with an aftermarket solution if you want solar would that prevent you from purchasing a Scout?
There’s definitely a factor in it. Tesla was supposed to be the first—with the Cybertruck—to offer an automatic solar tonneau cover, but then they bailed on it. But keep in mind, Tesla is also the one that wants you to always charge between 20% and 80%, and then you find out the vehicle doesn’t go anywhere near what they claim.
True boondocking—or camping where you don’t really need to worry much about consumption—comes down to solar, not just burning fuel. You’d realistically get 10 to 20 (or more) miles a day with a 1-kilowatt setup. I’m happy to demonstrate that with a 1-kilowatt array and an EcoFlow.
To answer your question, I’m not sure how much it would affect my purchasing decision. But at minimum, I think it would be smart to include solar connections for aftermarket setups—so if people add panels, there’s a clean way to feed that power into the vehicle’s inverter and battery.
*One idea is to use the existing charge port to feed solar back into the vehicle—but that’s clunky, and it’s exposed on the outside. Another option is tapping into one of the charge ports inside the bed, though that means dealing with visible wiring.
I think the cleanest solution mirrors how the Cybertruck’s bed cover works: it’s automatic, integrated, and discreet. Even if someone doesn’t opt for the automatic cover, there could still be built-in contact points—hidden—that connect directly to the vehicle’s charging system. (Think about the future of EV charging is wireless)
**Granted, I always think of emergencies as the best application for solar integration. If you were stuck with no fuel, could your vehicle charge itself—enough to keep you cool or warm, or even build up enough miles to get out when the time came—even if it took days? Or, with the same thinking, if the vehicle sits for long periods without access to charging, can it slowly recharge itself?
For a mobile office setup—which I use often in the Lightning—not having to worry about consumption would definitely add peace of mind.
Lastly, an EV that charges itself by design.. it hasn't been done and it's good marketing.
Reactions: SrfnFly227
Thanks for answering my question. Appreciate the insight.
I don't want an integrated solar option. I would like some upfitter capabilities that would make it easier to use my custom solution, but those capabilities would be generic so other people could use them for other things. If Scout included an integrated option, I wouldn't buy it.
This is the key. Many of the struggles of all the failed automotive startups are due to trying to do too much too soon.
I totally respect that answer and agree that you got to start somewhere but even the 2010 Prius had solar panel built into the top to run accessory
