Rain/fog Lights in the rear
Scout_Lookout
523
1,683
Rivian has rain/fog lights that you can turn on in the rear of the vehicle that greatly improves visibility in rain and foggy conditions. These lights are very bright red lights that are easily visible from distance, but one of the reasons I like to use them in my Rivian is they also disable the auto high beams which of course in those kind of conditions reduce visibility. I would love to have these on the Scout's as well because they are very useful. :cool: 🤙
Upvote 2
I have never heard of that feature. Sounds interesting.
My Tesla has them too. It basically keeps one brake light on. I believe they are required in Europe. I don't use auto high beams so can't comment on whether it disables those. It has separate toggles for front and rear fog lights.
They're great! They are standard in Europe for the most part and Tesla had something similar but what I like about Rivian's set up is they are a pair of low separate lights from the brake lights and if you can run them on dark non lit roads/highways to make the vehicle that much more visible to others.
Looks great, clean install. I really like the dual light colors too, for multifunction.
The clear lights are great for backing in the garage (my front windows are tinted to match the back windows), or when I’ve had to hook up a trailer at night. The yellows are good for super dusty areas when with a group, or really foggy highway conditions. For the yellow lights I originally looked at a Bullet Proof Diesel Mount, but after the install it got damn expensive (plus I didn’t want to do something that could cause a rear window leak).
This is definitely a European thing, and I don't expect these behemoths to be sold across the pond, but I would love to see prewiring for lights in general. My Toyota came prewired for auxiliary front lights and roof lights which was really nice. I don't need roof lights, but prewiring for front and rear lights would be great so the customer could add their own lighting as desired. At that point, Scout could easily offer a rear fog light kit in their store, using the existing wiring.
Yeah as much as I would like this to be a standard feature I have a feeling the A/M is going to be huge for SM and they will surely have some serious lighting kits. But pre-wiring is a solid idea too.
I have to assume that's in their plans based on the switch blanks they're putting in. In my Toyota, I just had to buy a factory switch, pop it in the slot, put a relay in the fuse box, and I was good to connect lights. The harnesses were already there and connected to the dash, high beams, etc. It'd be incredible to have a user-selectable menu where you dictate how your lights come on. With switch on, with switch on AND high beams on, with reverse lights on, etc.
I think having really bright reverse lights is a very useful request. We've all been backing up at some point in the dark, and barely able to see where we're going.
My father and I put a 65w light on the rear bumper of our '97 Wrangler back in the day. It was super useful. Both in normal day to day driving, but also on the trail, and at camp.
I've also requested "around the vehicle" lighting. This is the "you pulled up to your campsite at dark:30 at night/morning, and have to setup/takedown your everything in the darkness". Of course with headlamps now it is easier. But if the Vehicle had even relatively soft lighting that extended ~6-15ft from the vehicle in any direction, that would be amazing.
Both for the "I parked here in the dark and have no idea what I'm about to step into" situations, as well as the "lets load up the vehicle with my arms loaded in the dark as I stumble over this stump here" situations.
Basically, imagine using a ~50-200 lumen Armytec/Zebralight headlamp beam coming from the roof rack/side of the vehicle on each side, and thats what I'm wanting.
Actually, new feature request idea: Liftgate floodlight. When the liftgate is open, have a button that lets a light built into the bottom edge of the liftgate, illuminate under the liftgate, and the surrounding area.
My bolt has this issue with its center mounted reverse light, it’s too dim. However GM has the issue of using it’s reverse lights for the “ courtesy lighting” so the simple act of exiting or unlocking the car in a parking lot will cause people to stop thinking they’re about to exit the spot, I see it all the time, especially since the majority of our cars are GM.
Yet another couple of features that my Rivian has. The reverse lights are super bright, but the cool part is you can set them to stay on for up to 5 mins after you get out of the truck, and with this setting the headlights stay on as well.
And then in camp mode (which undoubtedly SM will also) you can turn on the mirror lights also, and it will silent all locking sounds too.
That liftgate lighting idea though is a really good one, and to be able to switch the level of lumens would be awesome!
Reactions: maynard and Logan
