Nice to e-meet you but I am glad you are not the CEO of Scout. I have been driving EVs for 15 years now and SSBs are like fusion energy, always just 2 years away. Go back and read your posts in this thread. I can't even count the number of times you said "should, will, etc." It's all pie in the sky at this point. As @Cranky Canuck said, there is ZERO use of these batteries outside of the lab and test track. We have ZERO longevity data or data on how they will respond to real-world use (vibration in particular has been the bane of SSBs as they are quite brittle). The good news for Scout is that it will be trivial to use the new tech once it's proven. It's like changing the type or size of fuel tank in your ICE car. The engine doesn't care what shape the tank is. It just needs X Amps at Y volts.PowerCo and Quantumscape are now dealing with OEMs to produce these solid-state batteries. While I agree with you that wide-scale deployment of Solid State Batteries (SSB) will be closer to 2030, the initial use of it with cars that have low volume will start next year. If I was the CEO of Scout, I would be doing everything in my power to be sure that Scout was one of the first to use this battery. The low volume and timing of the Scout factory make it perfect for Scout. I personally will wait for a Scout until they have this battery as an option even if it costs more. It will be worth it. The generator using fossil fuel is a complete and utter waste when SSB will do that and much more.
Scout cannot afford to have pictures of vehicles on flatbeds floating around on the internet. Scout should stick to proven tech and let others figure out the new stuff (they call it the bleeding edge for a reason).
If you are waiting for SSBs before buying an EV, I predict you will be waiting a very long time.
