1904 Carburetor
retiredfire
1
0
My 64 Scout has the 1904 carb which I have rebuilt and gone thru a couple of times and cannot keep it from flooding from the "vent" hole on the top. I have looked at new replacement ones and all of them have the choke connection turned exactly 150 degrees opposite from mine. I have taken it off so many times that now where I connect the fuel line is stripped and won't tighten. I thought I had found one on ebay but the flange that connects to the motor is wider than mine, something new that I learned. Any help would be appreciated.
Check one of the forum sites that specializes in Scout's. The problem you are probably running into is the basic 1904vwas produced for a number of applications and manifolds, several Ford's among them and what is sling for $100 on ebay.
Leaking out the vent to me means an out of adjustment float or valve that is not seating and not shutting off flow of fuel.
If Grose-jet has an application for the inlet valve thst would be ideal. I used those on my MGs
Edit: you would use a Grose-jet HY-33
At this point I would opt for a 4 bbl that fits the manifold
Here's a good article for carb flooding
https://www.carburetor-parts.com/fix-carburetor-flooding Or more tech info here
Personally, I've had good luck with Mike's Carburetor. There's a lot of info on that page. Binder Planet is also an excellent source but can be kinda hard to find the right articles.
If you're looking to keep it original you need an R2494 1904 carburetor. The number should be stamped on the flat bit sticking out next to the bowl.
