What feature(s) do you hope that Scout does NOT include?
Start/stop button, certainly not needed on the full EV version (don't know if it's really needed for the Harvester or not). Should just turn on when the door opens and be ready to drive when brake pedal is depressed and put in drive.
I agree. The Start/Stop Button is a holdover from the ICE age. An EV doesn’t have a starter, so there’s nothing to start, right? So, it stands to reason that the concept of “starting” a car doesn’t really apply to EVs.
I’m an EV novice. I hadn’t even considered that. I’m learning new things everyday.
Reactions: klsscout007
The start/stop is to make the human be more interactive whit the vehicle and to not rely on AI or heavily worked software. Allow the driver to learn their vehicle.
It just looks for the brake pedal to be pushed in most instances, nothing to fancy. Even ICE vehicles look for this.
Reactions: Dana
They had a key fob in the Scout reveal didn’t they? If there’s a key fob would there be a start/stop button or would the fob just need to be in the car for it to “turn on”?
ICE vehicles use the brake for an ignition lock. Not to start the car. All pushing the brake on a car does it make it begin to look for a key fob signal. Probably the same way Scout is going to do it.
Even early Tesla's had a Start Stop.
Yes. I was just saying EV & ICE both look for brake pedal push. Not what they do with the information is the same. Sorry if I wasn't clear.
That's a very good question. Personally I like the latter as long as they also have some kind of keyless entry system. If I have a fob I don't want to fish it out of my pocket just to unlock the door.
Reactions: bb00799
Here probably why they are putting a Start Stop in the vehicles is due to the contactors.
You know ICE vehicle drivers already know with fob on them, pocket or purse all they need to do is press Start/Stop then press the brake pedal to put the vehicle in gear. Let's just eliminate the extra step of pushing a button before hand. I believe there are a few manufacturers that have eliminated the Start/Stop, including Rivian.
Reactions: OH1984
My 2013 uses a regular key. I have a lanyard around my neck with that key on it whenever I go. I’ll just be happy not to have to do that anymore.
My wife bought herself a budget friendly 2022 Ford Maverick Hybrid and it has a key, drives me crazy.
Im a physical touch person. I like knowing how my car is responding. Might as well remove the brake to skip that step too. Along with the accelerator pedal.
Many vehicle manufacturers have implemented an automatic park feature that engages when the driver unbuckles their seatbelt or opens the door while the vehicle is not in park. I understand some manufacturers had some roll away problems way back when. But, not a fan.
Our ID.4 is touchless. Get in car, sit down in seat, depress brake, and car turns on. For redundancy they do have a start/stop button but that's really in the event you want it on without actually sitting in the seat/etc. The only point of contention I have on it is when you're parking in a tight spot and slightly stand up in the seat to get a better view of the curb or whatever it'll slam it in park and stop you right there.
