Scout Patents
Based on a couple of images I’ve seen of the bench seat in the Terra. I’m curious if that box is part of the bench seat configuration I haven’t looked at the patent specifically, but based on the things I have seen it looks like it would be under the non-moving center seat of the frontbench
Yes that is what it said. Take a look. Here is page 8.
Two cool patents just found
Battery Cooling: US-20250253446-A1
Also tells us that cylindrical cells will be used. No unified cells from powerco.
ONE PEDAL ROCKING TO FREE AN ELECTRIC VEHICLE FROM A STUCK CONDITION: US-20250256586-A1
I’m not certain the cells will be cylindrical. The patent doesn’t require them to be; many times patents just have to illustrate something that’s not critical to the invention. In this case, the invention doesn’t require the use of cylindrical cells.
A battery system 22 is supported within a battery housing 24 that is secured to the chassis 12. The battery system 22 includes battery cells 26 positioned within the battery housing 24. In some implementations, the battery cells 26 are cylindrical type cells. In some implementations, the battery cells 26 are prismatic or another battery cell geometry. Each of the battery cells 26 includes poles 30 (e.g., a positive pole and a negative pole) connected by busbars.
There is a patent for being able to change modes; but I want to know what “Baby Changing” mode is.
As newborn one of my kids would only fall asleep with a drive - so I would occasionally find myself in the middle of the night at a cold and sketchy parking lot changing diapers. Maybe that mode was for past me.
View attachment 12689Changing a blowout all the way up the onsie as semi trucks blast by you in the middle of knowhere with a screaming squirming toddler is on every parents check list
