Scout Compass in Vehicles and Accessory
THil08
  • Aug 14, 2024
    864
    999
    NOYB, New Jersey
    Will they be a True North Compass or a Magnetic Field North Pole Compass?
    True North uses the North Pole which never moves.
    While Magnetic Field North Pole moves every couple of years.
    I would hope its a True North Compass.
    Reactions: eddiet1212
    I’m pretty ignorant on the subject, but I would assume it’s a simple magnetic compass. How does a true north compass work? I’m assuming that to to point to the actual North Pole it would need position info as well as the location of the magnetic pole?
    If it is a magnetic compass - then true north. If it is a GOOD magnetic compass - then allow for it to be adjustable so you can set it to where you are. As it is, I would say keep it priced reasonable, and just go with magnetic north. I really don't need a multi hundred (or thousand) dollar boat compass in my Scout.
    Now one thing that could be "nice" if it could be done cheaply is a GPS compass. Normally GPS system require movement to determine direction. But there are GPS units that have multiple receivers that can deal with direction without movement. I will probably get one for my boat eventually - but that is +/- $1k. But a magnetic compass and a few brain cells is probably a much more economical option. Still it would be nice if the vehicle GPS knew the direction before I start moving (I hate doing circles in parking lots because the GPS has no clue which direction is which before I start moving and going the wrong direction).
