Battery used
MDR
Dec 29, 2024
5
9
Jacksonville
I asked Scout whether they would use these next gen batteries,
They responded
Hello! The main battery is projected to use Nickel Manganese Cobalt (NMC) chemistry, which is common in modern electric vehicles for its high energy density and performance. However, you can certainly post the suggestion on our community forum at https://community.scoutmotors.com/ (https://community.scoutmotors.com/)!
Thanks for posting their reply.
Reactions: THil08 and maynard
Battery Chemistry (general)Specific Energy (Wh/kg)Energy Density (Wh/L)Charge/Discharge RateCycle LifeThermal Runaway Temperature (°C)
LFP90-120; <300 theoretical300-35020C; theoretically, but other aspects of the system will generally constrain this to 5-10C.2000-5000270
NMC150-250; <300 theoretical500-7002C1000-3000210
SSB (lots of different chemistries, so this is a big range)250-550~800-1200~2-20C; some claim higher, but generally other aspects of the system will likely constraint this to a maximum of 5-10C.claims range from 1,000 to 100,000>250
I have my doubts about the Verge motorcycle. They claim it is in production, but quick google showed that it was a limited production run (100 units). Their extended range model has a 33.3kw/h battery. Hard to guess how many of the SS bikes will be made and how quickly they will make them - but there is a big difference in scale between numbers and battery size between Verge and Scout. Oh, and the 10kw extra battery size on the extended range verge cost an extra $5k - so they have a bit more margin to play with than Scout as well.
Something will be first with a SS or semi-SS battery. But I suspect it will still be some time before new battery tech will be available for mass production at reasonable quantities and price.
In the past Scout has posted they expected NMC for the EV and LFP for the Harvester. I do not know if that has changed. I assume the thought was the smaller Harvester battery would need more C capacity and cycle life to have similar performance with it's smaller battery, while the EV would be more sensitive to battery density due to the larger battery size.
It so far out, probably another 25 years before its mass produced. Unless China is able to make it for mass production which from what I have read it's a very expensive transition of tooling for SS, and then maybe US car companies can import them and reverse engineer it.
I know that BMW is mainly focusing on Lithium-Ion Technology since SS is too expensive upfront to mass produce at scale. And that it would be too expensive for the consumer.
Watched a handful of videos on the Donut battery. One made an interesting observation. Apparently Donut made an investment in a company working with nano-materials and capacitors. Their capacitor had a lot of similarities to the battery that Donut was talking about. Charge speed and profile, non-lithium, forget if they mentioned density. Of course capacitors come with their own set of issues - those were not addressed. Even if they don't loose charge rapidly, they tend to have virtually no internal resistance and can very rapidly discharge (imagine 140kw/s arching in a fraction of a second - maybe not technically a fire or an explosion, but hotter).
Well, last week Donut released the results of independent cell testing. For a day or two, youtube reviews were positive. This week, the same test result are being viewed as VERY negative. They provide a fingerprint of cell chemistry (cell voltage, charge rate curves, etc...) - and the fingerprint is that of a NMC cell. Very unlikely that their miracle lithium-less solid state battery would carry a NMC fingerprint.
  • Wow
Part of the problem is that the doubt claims amount to “it’s amazing at everything with no downside”. The first thing they tested is one thing, and it’s in line with a good NMC battery, ie it’s technically near the claims for charging speed, but that alone is nothing special. So some folks just looked at it and said it supports their claims, but experts immediately noticed it seems to just be a good NMC cell, measured in isolation. Even at that it didn’t quite match the claimed specs. But what makes donut suspect isn’t primarily the charging speed, it’s that plus it’s cheap, contains no lithium, and lasts forever and handles extreme temps and is solid state and no precious/toxic/difficult ingredients. The published test sorta confirmed the charging speed , but on closer inspection made the no lithium claim very suspect, and didn’t do anything to support any other claims. On top of that, many folks find their attitude and tone consistent with what we’ve seen with past cons.
It may not make any sense that someone would make claims that were inevitably going to fall apart on closer inspection inspection, but we’ve seen it many, many times. It’s like watching an adult struggle with object permanence, they think they somehow will never get caught. I guess some people’s brains work different. That or maybe they’ve discovered some amazing new tech that has escaped the thousands of other entities researching it. In any case we’ll find out soon enough with further testing and analysis. Meanwhile, I wouldn’t give them any money.
But I will happily eat my words if I’m wrong.
Additional to donut labs’ claim… BYD is also claiming to have 2 new batteries coming. One is a Sodium Ion and the other was solid state as well. I believe the Sodium Ion version was going to be mass produced this year.
BYD is a real battery manufacturer who doesn't make scammy claims. Donut is a scam company trying to get investors to throw bad money after good.
The sodium battery is unlikely to be put into long-range EVs because of its low energy density, but it will be replacing lithium in stationary battery energy storage systems, dropping prices for all batteries as demand pressure is reduced.
Some commuter BEVs in China have or had sodium batteries, but the energy density is low enough that the option has not been popular. For example, the JMEV EV3 had the option, but no longer does.
Several sodium-ion batteries are past pilot production and in small-scale production with larger factories for large-scale being built.
SSBs will be moved into pilot production by CATL and BYD, among other Chinese companies, in the next 3-5 years. The US companies claiming their SSBs are production-ready seem to be misunderstanding what large-scale production really entails.
Donut doesn't even have a battery, much less a factory. The CEO will be back next year with some other extraordinary scam.
