All terrain tires
Agreed with everything here.
And while strange, it is common to have a non-standard version of a tire for use as the OEM tire on a specific vehicle. The Cybertruck was one of those as well IIRC. Something about it being a normal tire, but with already-reduced tread depth for better mileage? Either way, its surprisingly common.
I do hope that we get these options from the factory:
  • "burly" All Season Tires
    • Likely the best choice if you don't think you'll ever really go off of pavement (or gravel).
  • "On Road" Biased All Terrain Tires
    • A good choice if you predominantly drive on pavement, but do actually venture off pavement enough to pay the efficiency hit. I'd call these the "I drive on lots of crappy forest service roads, but don't do "trails" with the vehicle tire.
  • "Off road" Biased All Terrain Tires
    • You actually offroad/take it on trails with some regularity. You want the grip, and durability of real AT tires.
I'd probably be most interested in the "on road" biased AT tires. Because while I do actually get off pavement, since I'm not doing "trail riding at the moment, the on road biased AT's are probably my jam.
My Jeep has a set of Cooper Discoverer AT3 XLT's that fit the bill pretty well (and are actually quite quiet for what they are, way quieter than the Duratracks I had on them before), but I'm not set on them at all. But would probably want something in the same realm as them as my preferred tired. But the BFG AT3 is great as well, and I wouldn't be unhappy with that.
Example of "on road" biased AT tire.
I had these on my Power Wagon. They were a good tire, especially for a HD truck.
Reactions: Logan
Depends on where in my ranch I am. I have managed to get stuck in black dirt, and wet clay, and watched others get stuck axle deep in soft sand. My whole life has been learning curves of where not to drive in certain conditions. But the wet grass issue was just embarrassing. I was not dug in, just had -0- traction.
My SxS, old Jeep and Tacoma tend to do a lot better than full sized trucks, or worse yet 3/4 and 1 ton trucks. They tend to float over bad patches rather than dig in and stop.
