5klbs towing cap with gas range extender?
To be fair, those are also mid-size trucks, not full-size. To be competitive Scout really needs to aim higher.
I fully agree. They need to. I dont think they need to be the 14k that the Ram is, but 7500lbs isnt competitive at all.
Was chatting with AI and it mentioned the 3500kg is indeed a limiter for licensing reasons. It mentioned thermals and battery buffer management being the issue.
My fear is they have to limit it based on 'all the bad things could go wrong at once' ratings rather than what is most likely. Like if they say 'well, you can only pull 7k lbs if you start towing with an empty battery, when its 100 degrees and you immediately go up a 7% grade for 15mi'.
Like, its quite easy to plan around stuff like that, especially with some smart software.
My hope is a minimum of 6k for the Traveler. 6500 would be better. Under that puts it below non full size SUVs like the Grand Cherokee. Ultimately that seems like a huge swing and a miss.
Range anxiety while towing is a legit concern and it seemed like the Harvester could solve it. Doesn't matter how much range you give if people can't tow the things they want.
