1961 Scout 80
350ci, front disc brakes, power steering
My uncle on the farm was an early adopter in 61. In fact there were probably a half dozen running around our community. This is back when you could buy the Scout and other IH small trucks through the same tractor dealership. Most if not all of the tractor dealers also had the pickup versions of teh 80 at the time.
As I hit I got to drive it mid-teens in the sixties I was able to out a ton of offroad miles in it as well but the two things I wil never forget on its first day or two on the farm, first is my uncle was sure iut would fit down a row of grapes (9 feet between vines) If it did not have side mirrors he might have made it. Then he proceeded to demonstrate the 4wd capabilities in an open field and shifted the gears inside and immediately became stuck as he has failed to engage the locking huns.
After college I helped rebuild the floorboards and for the mere $800 he got for it let it slip away
Thanks for sharing!
Similar threads
  • Showcase: Item Showcase: Item
Replies
0
Views
280
Replies
0
Views
538
Replies
0
Views
395
