Wheel base
Jim Nichols
161
116
Rear wheels should be back farther on SUV than Scout II. On the Terra pickup should be in the middle of the bed.
Electric platforms typically see the wheels farther out to the edges except with the pickup where centralizing the weight over the rear axle makes sense. Plus if you want decent approach and departure angles you need the wheels out at the corners. At least where it doesn't impact break-over angles too much.
