Power outlets
The more they can make it operate just like a basic generator output, the better. I don't want to have to have a bi-directional charger in order to make use of this. I'd like to be able to plug it into the generator connection allready wired into my house, and also be able to help out neighbors & friends who are similarly wired.
Scout is "People. Connections. Community. Authenticity." Welcome to the Scout community. Enjoy the ride. 🛻 🚙
I would like to see power outlets 110v and 240 volts in The traveler also as home power backup
Welcome, this is a very friendly place!
I think the power options are influenced by the Terra being a work vehicle and the Traveler being a lifestyle vehicle. The Terra has 120V, 15A outlets in the bed, along with a 240V, 50A outlet. That is just the capability of the NEMA 14-50 outlet, nothing from Scout yet about what will actually be available. The Traveler has 120V, 15A outlets next to the charge port. I have not seen a 240V outlet in any photos of the Traveler. I don’t recall what either might have in the frunk, my guess is just 12V and maybe a 120V.
Without doing some digging right now I’m pretty sure both will support V2H (vehicle to home). I think this generally works through the charge port with some kind of adapter. From the way house electricity works, this has to be 240V to supply both 120V legs. And probably at least 50A to provide a very basic home service capacity. You have an inlet port and transfer switch on your house service to connect the Scout and isolate you from the utility.
