Improved HVAC Circulation
benne.jason20
Sep 14, 2025
4
Can there be thought to added additional HVAC vents in the rear passenger area on the B/center Pillers? The standard 2 center vents usually still leaves the rear hot or at a different temperature. Ever if they are small vents the additional airflow from the side help with circulation. Granted the roof is expected to have the large glass but this can be an extention from the rear center vents, possibly thru a floor duct.
There’s been quite a few requests for something like this. SM hasn’t posted anything about that. You are correct, the consensus seems to be the roof is large and might interfere with that.
A couple good follows are @Jamie@ScoutMotors and @CP1@scoutmotors they keep us updated from the manufacturer side.
Per @cyure. If you use the search button function and list a topic it will take you to all the various discussions already happening on the said topic. Many of us have learned along the way to use it to search for topics. It’s a big help when you’re just getting started since there is nearly 3 years of thoughts already on the forum. Check it out and you’ll see the thoughts and the possible issues with such venting. Have a great evening
This is a hot topic. At the moment they are showing standaard console rear vents only.
Reactions: J Alynn and cyure
