If the carrier is easily removed, we would probably get the backpack and the carrier and only use it when we’re camping.
I have been lobbying for a removable carrier for some time. That would the best. The Traveler with the carrier is 28" longer than the vehicle it will replace and the access door in the garage to the house is directly in front of that space. It makes for a tight squeeze into the house.
I need to measure my Jeep. It has a steel bumper on the front that has these two little bump out on it and then my tire is a 33 so I think it’s longer than I think.
I’m all in on the tire carrier. I have a cabinet I can take down in the garage if need be. Her and her whole tire carrier fabulousness are going in the garage.
With the BEV the spare can be mounted under the floor where the harvester is going. I can always use more storage on long trips so having the option to place the spare tire under the vehicle and then attach an extra storage space to the rear tire holder is a win.
You know me and questions. Let’s say someone has a 35. There would be enough room under the floor of the Traveler for a 35” tire?
Good question... Hopefully we receive an answer to this in the new year. If it will come stock with 33s then I will take a gander that at least 33s will slide under the vehicle. I could be totally wrong though... I know on my current Ford, I can fit a 33 in the spare well but it's real tight, I would not be able to fit a 35 between the frame rails I believe.
Under the traveler is questionable with traveler. Pretty’s sure they said 35’s would fit under Terra. But struggling to recall
I t was my understanding that the 33" will fit under the Traveler but 35" requires the spare rear tire carrier. I think this was all but confirmed in January of this year.
