RV Towing
I'm also hoping the Traveler can be towed and that other considerations for towing behind an RV are being considered. Like potentially using the front recovery points as a base plate (there are several Jeep after market bumpers that support this), optional mounting points for tow chains and some sort of "smart" braking mechanism. That would be a real game changer for the RV people looking to get into an EV...
Since the differentials can be locked, it's not inconceivable to hope that they can also be opened. If the differentials can't be set open, then it won't be possible. ZF, the probable drive unit / axle manufacturer, claims that their ebeam axles can be optioned to allow open differentials.
I hope this is something Scout Motors takes into consideration because it would be a nice option to have. We don't currently need to flat tow but have pondered the decision to trade up from our smaller travel trailer into a smaller Class C. I imagine the weight of the Traveler could be an issue with some of the chassis options for motorhomes. Unless of course you're talking a diesel pusher lol.
Personal opinion, it will not be ZF. I do expect an announcement sooner rather than later.
What I've read so far indicates an electronic locker standard in the rear axle with an optional front electronic locker. Since they have used the "electronic" verbiage, that tells me it's selectable and can probably be engaged / disengaged automatically depending on drive mode, or, since they are also promoting the use of tactile buttons and switches in the cockpit, manually as desired via "push button".
Default will certainly be open.
There are at least two others. There is one that I think is the most likely candidate. I just cannot say the name at this moment. But, it is very familiar. ?
Sure be interesting if they got a Dana under there. *begins frantically googling axle makers with electronic solid axles in the works*
Hmmmmmmmm seems that last year Dana announced a partnership to produce electric axles for a future project of an undisclosed American vehicle manufacturer: https://www.toledoblade.com/busines...o-improved-second-quarter/stories/20230728114
Reactions: TreeKiller
Confirmed - in the podcast that was just posted, Scout's Shaheen Karimian confirmed user selectable lockers with the ability to manually lock or unlock each axle using physical buttons or switches in the cab.
