Instead of separate box for pickup
Jim Nichols
161
116
You should make one version with different tops like Traveler/Terra pickup. Maybe 124" wheelbase because of the 4 doors. Then come out with the 2 door version that most here want. New Bronco 2 door is almost 40% of sales. It could be the same as the pickup from front door forward but on 100" wheelbase.
Where are you getting your sales data? I have only seen the sales figures split by Bronco and Bronco Sport.
A direct quote from Forbes, "Most shoppers (over 70 percent, according to Ford) have been choosing the 4-door"
Sales numbers on Bronco 2-doors are hard to come by as Ford hasn't broken them down. It is also complicated by two-door supply issues throughout production so far limiting the number.
Jeep on the other hand runs between 12-15% two-door Wrangler sales with the JL generation.
Wow that is way less than I would have guessed!
Bronco board 62% 4 door 38% 2 door. Forgot to put almost before 40%.
And this is with heavy commodity restraints on the 2 door. I will say 2 doors sit on the lot it seems longer than the 4 doors.
Do Remer the original Scouts were 2 door only and the only difference between pickup and non was different roof. Temovable seats can be removed but without a roll cage in rear seat you might not be able to have both
