Cruise Control Following Distance (and other assists)
Crazychicken563
Sep 29, 2025
55
159
Columbus, OH
We know that Scout will offer some level of adaptive cruise control, lane assist, maybe limited self driving of some sort. I'd like to open a discussion about the behavior of these assists. Voice your experiences regarding vehicles you've driven and what you did/did not like about each of their driver assists.
I'll kick things off with:
2021 Polestar 2:
This is my daily which I've driven for several years now.
Things I like
1. The following distance is adjustable from the steering wheel rather than hidden in some touchscreen system menus. Additionally, the following distance is tuned very well. The closest distance puts you roughly 2.5 car lengths behind the next car at highway speeds, and the max distance is about 4 car lengths.
2. The following distance is relative based on speed. Perfectly tuned for highways, but it closes the gap when driving on city roads. At 30ish mph the closest settings puts you roughly 1 car length behind the next car, sometimes even less than that. Personally I find that a bit close, but that's why it's important to have quickly adjustable and intuitive following distance controls on the wheel, which this car has.
3. The most recently used following distance is remembered the next time you turn on cruise control.
4. The passive lane keep assist is firm, but not intrusive. It only kicks in when you are on the edge of the lane, but it is not strict about keeping you in the center. This is different from the actual steering for you mode (called pilot assist) which will do its best to keep you in the lane but does not fight you that hard if you make adjustments yourself. You can actually tweak this behavior in the settings so that lane keep assist will either A - give a tiny bit of steering input to help you out at the edge of a lane, or B - just vibrate the steering wheel when you are about to leave your lane, but does not actually help steer). I love that there are settings for this specific behavior.
5. In stop/go traffic the cruise control will creep along at absolutely any speed and it will maintain a 1/2 car length to the next car. This is ideal and I would love to see this behavior in the Scout (rather than deactivating the cruise control below some X speed)
6. It maintains speed when cornering (in sharp contrast to the car below)
7. It does not over-react to people changing into / out of your line (a gripe a have with Toyota's implementation that I will detail for the next car)
This I do not like
1. When pilot assist is enabled, it will constantly raise an alarm that you need to keep your hands on the wheel even if you already are. The way it detects that you are "holding the wheel" is by looking for steering inputs, not actual tactility. Because of this, using it on a straight line road (where it's arguably most useful) is effectively impossible. You have to jerk the wheel a bit to get rid of the warning which is just rediculous when driving in a straight line. The other way to get around this (and this is what I usually do) is by quickly turning pilot assist off and then back on again. It's a distinct button on the steering wheel so it's easy to do, just extremely annoying to have to do.
2. When the car comes to a complete stop, even with cruise control enabled, it will not go unless you press the gas pedal. This is probably a safety feature, but it is really annoying in stop/go traffic since hitting the gas pedal resets the radar portion of the following distance. Probably just a matter of tuning things better.
Overall I'd give the Polestar's adaptive cruise control a 6/10. 9/10 for the following distance and 3/10 for the execution of the pilot assist steering. Having the "keep your hands on the wheel" alarm going off constantly when you ARE paying attention and ARE steering is a total dealbreaker and I pray Scout does not make a mistake like this.
Next car
2021 Toyota Rav4 Prime XE:
This is my dad's daily, so I have limited experience driving it (roughly 20 hours total), but in that experience I have several immediate negative opinions about the driving assists.
Things I don't like:
1. The cruise control does not remember your following distance between car restarts. It always resets to the maximum distance which is FAR. It also forces steering assist to be ON every time you first turn on cruise control. This leads to having to click a combination of buttons 5 times in order to set your speed just once the first time you turn cruise control on for your drive (assuming you want minimum following distance and no steering assist). Not good.
2. The distance is adjustable on the wheel, but only with a single button that cycles through the distances. If you overshoot your target distance you need to cycle through everything again. Distracing - eyes not on the road.
3. The adjustable distances range from "far" to "I can't even see the next car". The closest one puts you roughly 5 car lengths behind the next car.
4. The following distance massively over-reacts to people entering your lane. A specific example is when you are driving at constant speed and a car changes into your lane. Even if they immediately accelerate to match your speed or even exceed it, the Toyota will slam the brakes and then very very slowly accelerate back up to speed. The Polestar is far better at this - it seems to do some sort of brief distance over time calculation to check if the gap betwen you and the car that pulled into your lane is increasing or not, and will maintain speed (or decelerate) accordingly.
5. Cruise control will shed a ton of speed when taking corners. So much so that it feels like it's unsettling the car and putting far too much load on the outer front tire. Not pleasant.
Overall rating for the Rav 4's adaptive cruise is 4/10. It's annoying to use and gets in the way more than it helps. It feels overly cautious to the point where it has put me in dangerous situations. I therefore have it turned off 90% of the time and so don't really have opinions on the quality of the steering assist. I also do not have any experience with the behavior of this system at low speeds or in stop/go traffic.
My main takeaways and hopes for Scout:
1. The following distance is well tuned both for distance and for other vehicles being detected / undetected, and can easily be adjusted for both closer AND farther settings through distinct controls on the steering wheel
2. Steering assist does not generate false negatives that you are not holding the wheel when you are
3. Stop/go traffic is gracefully handled by the driving assists
Considering Scout is building on top of Rivian software in some way, I figure it's a reasonable assumption the the adaptive cruise control settings will be Rivian-esque? Would love to hear some feedback from current Rivian owners about the behaviors of their adaptive cruise control systems and driving assists, both positive and negative. Would also love to hear people's experiences in other cars! I hope we can croudsource some absolute dos and don'ts regarding driving assist behavior.
2021 Polestar 2:
Things I like
This I do not like
Next car
Not a current Rivian owner but Jamie stated the plan is Level II+. So whatever that entails that’s the plan that’s been announced by Jamie on the forum.
TBD for how similar Scout's implementation will be to Rivian's, but I have zero complaints from my R1T (with all of the improvements that have come to Driver+ since 2022 via OTA's). The system works very well, and you can do things like adjust distance right from the steering wheel easily. You can very easily engage/disengage from the stalk in the Rivian too. I barely keep a finger on the wheel at times and have no issues with annoying alarms. I have not experienced any phantom braking. When I first got the truck and before the OTA's, the system had a harder time taking curves smoothly and seemed to pass other vehicles too closely, perhaps based on being too precisely centered. Like I said though, this is no longer an issue and I like the new lane-change auto resume and other features.
This is a decent vid:
Also, Gen2 Rivians had some additional improvements:
Co-Steer and Enhanced Highway Assist improvements​
Now, Gen 2 drivers can adjust their lane position while Highway Assist is active without the system disengaging. Co-Steer enables you to move your vehicle into a position within the lane that’s more comfortable for you in situations like driving beside barriers or passing a semi-truck.
Additionally, we increased the availability of Enhanced Highway Assist by over 50%, enabling longer uninterrupted stretches of hands-free driving. Rivian’s in-house perception system, which uses AI to fuse multi-modal sensor data to understand the 360-degree environment around the vehicle, has an updated model that improves lane centering, especially as your vehicle navigates highways with tight curves.
Ohh, this is exactly the kind of feedback I was hoping to hear. Ty!
Hard to believe there's a system with zero pitfalls but I sure hope so. Always nice to see zero complaints
Nothing is perfect, but I give Rivian high marks on SW and their implementation of Driver+
Everyone will have their own perspectives and opinions.
We know Scout is talking LII+, so should be a similar set of features.
I'm guessing Scout has a good chance to slipstream off Rivian's work here, which should also help with time to market.
2021 Polestar 2:
Things I like
This I do not like
Next car
All great points and I like them all. My wife’s Explorer shuts off the cruise when you come to a stop and it drives me nuts. It’s also too aggressive when somebody pulls out in front of you it slams on the brakes. One of the biggest points you mentioned was it staying with your previous setting. I feel like all settings should stay the same. If you’re in an off road mode, stop to check something out or relax, then go back into the truck it should remain in off road mode.
Teslas do this. I ABSOLUTELY hate it. Because it waits until the absolute wrong moment to slow down and it unsettles the car. Then I have to press on the accelerator when then causes another weight shift. Stupid, stupid, stupid.
@R1TVT, if the Rivian is in Cruise Control (not with steering assist) will it slow down in corners?
I don’t know if Rivian’s Driver+ and/or smart cruise control is included in their software sharing joint venture with VW or not, but just in case it is...
I have a Rivian R1S I bough for reasons other then the self driving & driver assist. I had a Tesla Model Y prior to the Rivian, and prior to that nothing else with any sort of smart cruise control or lane keeping features.
Rivian has an adaptive cruise control you can activate pretty much anywhere and any time you are not towing a trailer. Compared to Tesla’s similar feature the cruise control suffers from dramatically less phantom braking. The Tesla would balk at any hard shadows of vehicles that got cast into my lane of traffic. The Rivian has once or twice balked at a large riding lawnmower that someone had in their front yard, it seemed convinced they would ride across the font and into my lane of traffic. Which in theory could have happened, so I am willing to cut it a little slack.
Rivian’s Driver+ pseudo-self driving feature can only be activated on divided line highway type roads, and they may need to be “mapped” (white listed at least) by Rivian. I only drive on that kind of road every other month or so, maybe once a month. It does very well on them, it mostly picks a part of the lane to be in that doesn’t drive me nuts (I almost never used autopilot in my Tesla because it always wanted to drive a foot or so to the left or right of where I did, which when I’m respnasable for what it does I find hard to ignore). Rivian’s recently added co-stear also lets me move the Rivian over in the lane (with the steering wheel, you know, like I was actually the driver) and when I let go it keeps to the same position at least until it sees a car nearby or something. On many (but not all) highways you can let go of the steering wheel as long as you keep your eyes on the road. I find that great for releasing any cramp in my arm from holding the same position for hours on end. I don’t tend to keep my hands off the wheel for long because it just feels weird to not at least be touching the wheel. Interestingly with my hands on the wheel it lets me look away from the road for longer then a quick glance but with hands off you can only look away very briefly. D+ uses the turn signal to control lane changes. D+ does not seem to try to get you in the proper lane to follow routes, so you have to listen to one part of the car tell you where to be, and tell another part of the car. I imagine they could fix that, but since they haven’t addressed it yet there may be some complications I’m not thinking of.
Rivian remembers any settings you have made for following distance, I tend to crank it up pretty high. A dial on the steering wheel is used for this.
That is all the good stuff. The bad is controlling the speed is currently done by tapping a steering wheel button for “+1 MPH” or “-1 MPH”. The Tesla used a dial for this which I find much better given it is something I want to adjust a lot while I rarely want to adjust the following distance. Oh, the other “bad” is it doesn’t work if you are towing anything. Which is understandable, but it would be awesome if you could just let it haul a trailer for you.
Honestly it is pretty good. In contrast Tesla’s FSD which I didn’t buy but had several free trials of liked to try to drive into a lake at one particular part of town, so I’m not a fan. It also thought I lived in an empty field across the street from my house (and again, it should know better because I ask for directions to “home” and drive to a near by location and plug in to charge and leave the car for hours almost every single day, it isn’t much of a leap to decide “oh, that is where home really is!”).
So if Scout just gets Rivian’s cruise control, and driver+ features as long as they “translate ok” I think they would be very nice, I can imagine better, but I doubt there is better to just buy off the shelf right now and Scout doesn’t really have the time or resources to sink into home growing it before a 2027 release.
How many vehicles with smart cruise controls allow you to use it like a dumb cruise control where it just maintains a speed you set? I've tried and used the smart ones in the past, but I feel that I get too complacent behind the wheel when doing so. If I use cruise control nowadays, it'll only be the dumb variety for the sake of safety.
My Polestar 2 lets you disable every single smart feature for cruise, but it's all several menus deep in the infotainment. That said, it remembers your settings between drives, so if you turn off steering assist and following distance and such it stays off.
Oh, now that you mention it, that is a complaint I have about Rivian’s cruise, if you don’t want it to be ACC that’s too bad (or alternately “through the simple, intuitive, convenient method of attaching a 300lbs trailer you can select the alternative cruise control!”). I believe Tesla has a similar issue where you can choose for a single pull of the cruise stalk to activate smart cruise control OR autopilot OR FSD, and a double pull activates the “even smarter” mode, but you can’t get at “dumb” cruise. The problem is more acute on the Tesla because the smart cruise has a ton of phantom braking and I would generally prefer to get dub cruise than its idea of “smart”. On the Rivian I want direct access to to “dumb” cruise more out of general principals then because I have an actual use case.
I"ve driven a few cars with smart cruise control with multiple settings for following distance. I did not like any of them. They tend to have three options. With each one, the shortest distance was way too close. There'd be no way to stop in time if the car in front of came to a sudden stop. The same with the middle distance. Then there's the fact that if it's foggy, raining or lots of road mist, if the car in front of you is light gray or white, it doesn't see it, so thinks full speed ahead is fine and you have to fight the car so you don't rearend the vehicle in front of you.
I drive a Toyota with smart cruise, it has 3 settings like you describe. I think it always starts at the farthest setting, and I leave it there unless traffic gets heavy. If there’s a lot of traffic then other cars change lanes into the gap and the car keeps slowing down to increase said gap. The closest setting is a little tight, but by that point the traffic is significant so I’m very engaged and ready to react the same as is I weren’t using the cruise control. I still find it useful at that point because I can focus on steering and reacting to traffic without worrying about my speed so much.
I can go either way on adaptive cruise. I still find I get very lazy when cruise is on and I don’t focus like I should. I personally just prefer to be actively making decisions when I drive because it keeps me engaged
Same. I never use it. I’m so used to not using it I don’t think I would care if it didn’t even have it.
We have it on our Avalon. Wasn’t sure about it at first but I do like it and use it. It’s brought me up short a couple of times when I needed it. The headlight brights are adaptive too, and they work ok. Cant turn on hi beams permanently though.
